Kontron 986LCD-M/mITX
Intel® Core™ Duo and Core™ Solo Processors (mPGA478 socket, mBGA479 prepared), Support Yonah and Merom CPU core, Front Side Bus 533/667 MHz, Intel® 945GM + Intel® ICH7R Chipset, Intel® GMA950 graphic controller on board
Flat Panel Display Support, Dual independent Display Support (incl. 2x LCD)
1x 16x PCI-Express /SDVO external graphic card socket
2GB DDR2 memory support
3x 10/100/1000 Mbps Ethernet
8x USB 2.0, 4x RS232C, 2x IEEE1394, 1x ATA100 and 4x SATA150/300 IDE Controller, 1x Compact Flash socket, 1x mini PCI-Express socket for easy expansion of i.e. wireless LAN
On board RAID 0/1/5/10 support with SATA harddisk
7.1ch HDA / AC-97compliant audio output
Size: 170 x 170 mm (6.7" x 6.7")
i-Base MB899
Socket 478 Intel® Core® Duo Mini-ITX Motherboard
Socket 478 for Intel® Core™ Duo /Solo processors
Mobile Intel®; 945GM Chipset, Two DDR2 DIMM sockets
Supports CRT, LVDS, optional TV out or DVI
10/100 BaseT LAN, PCI Express Gigabit LAN
SATA x2, USB x6, Digital I/O, Watchdog timer
PCI x1, PCI-E (x1) x1, Mini PCI x1, Mini PCIe x1
AOpen i945GTt
INTEL Core Duo i945GTt
CPU: Intel Core Duo/Core Solo CPU (Yonah)
Chipset: Intel 945GT Intel ICH7MDH
Main Memory: Dual Channel Mode Support : SO-DIMM DDRII 667/533/400, SO-DIMM DDRII 667/533/400 x 2, 128/256/512MB & 1GB x 2, Max Memory : 2GB
Graphics: Integrated VGA Engine in chipset
IDE: Integrated ATA100 and Serial ATA Controller
LAN: Intel Gigabit PCI Express LAN chip
Sound: Azalia 7.1 channel codec on-board (ALC882D)
Slots: PCI Express (PCIe x1) x 1, Mini PCI x 1
Storage & Back Panel I/O: Adapter Connector x 1, IDE Channel : ATA100 x 1, Serial ATA Channel x 2, PS/2 Keyboard x 1, PS/2 Mouse x 1, DVI Connector x 1, Standard Video x 1, 1394 Port x 1, LAN Port x 1, USB Port x 4, COM Port x 1, Line_In x 1, MIC_In x 1, Speaker_Out x 1, Center/Subwoofer x 1, Rear Surround x 1, Side Surround x 1
On Board Connector: 4-pin 12V Connector x 1, CPU FAN x 1, System FAN x 1, Front Panel x 1, USB Port x 2, COM Port x 1, COM2 x 1, IEEE 1394 x 1, S/PDIF x 1, CD_IN x 1
BIOS:Award PnP 4Mb Flash ROM BIOS
Form Factor: Flex ATX (mini ITX)
Commell LV-677
CPU: Intel Core Duo and Intel Core Solo processors @ 667MHz FSB.
Memory: 2 x 240 pin DDR2 533/667MHz up to 4.0GB.
Chipset: Intel 945GM and ICH7-M.
VGA Interface: Intel 945GM integrated GMA 950 Technology.
LVDS Interface: 18-bit dual channel LVDS interface.Supports up to WUXGA panel resolution.
TV out: HDTV built-in.
LAN Interface: Intel 82537L PCIE Giga LAN
PCI Enhanced IDE: UltraATA100 IDE up to 2 ATAPI .
Serial ATA: Integrated Serial ATA controller facilitates high-speed data transfers at up to 150 MB/s for each of 2 ports.
Audio: Intel ICH7-M integrated with Realtek ALC880 High Definition Audio.
I/O Ports:1 x RS232 and 1 x RS232/422/485 Serial Ports, 1 x Parallel port, 6 x USB2.0 ports, 1 x DB15 VGA port, 1 x IEEE1394, 1 x PS/2 keyboard and mouse ports.
Extended Interface: One PCI Express x 16 bus add-in card connector, 2 x Mini-PCI socket
SSD: IDE1 supports DOM, 1 x CompactFlash socket (underneath board)
GPIO Interface: Onboard programmable 8-bit Digital I/O interface.
Power supply: ATX P/S or DC 8~21V used optional.
Power requirements : Most core duo use a max of 31watts, and the DC board version has built in regulator so you only need a uSDC20A from mpegbox and you will get ypur 12V/5A + 5V/3A onboard regulated for devices such as hd's and usb hubs. The onboard regulator also survives engine cranking and ranges from 8 to 21 Vdc
Endura TP945GM
Intel® Core™ Duo, Celeron® M, LV and ULV processors
Intel® 945GM Express chipset; 667/533MHz Front-Side Bus
Two DIMM sockets; Up to 4GB DDR2-667 memory; Dual-Channel memory
Intel® GMA950 Graphics; x16 PCI Express graphics slot; 18-bit, dual channel LVDS; TV-out header; VGA output; Dual independent displays
Intel® High Definition Audio; Eight channel CODEC for 7.1 audio; S/PDIF digital audio output
Mini-PCI Type lllA socket; PCMCIA Type II socket; Compact Flash Type I socket
Single or dual Gigabit Ethernet; Eight USB 2.0 ports; Four RS-232 serial ports
PS/2 keyboard and mouse ports; IrDA interface
Two SATA 1.5 Gbps ports; One Ultra ATA100 port
Phoenix TrustedCore™ BIOS
TPM 1.2 header
GPIO port
ACPI 3.0
RoHS compliant
