Показано с 1 по 3 из 3
Тема: Плагин iGO8
    Пользователь Аватар для Sergleo69
    По умолчанию Плагин iGO8 к CF
    на забугорном сайте ихние умельцы во що придумали, на себе немогу испытать незнаю как вот еслиб знаюшие люди глянули
    Perilous IGO Helper Apps
    Install Howto:
    Copy or Extract the Files into your Program Files Folder.
    Open the folder containing these Files
    Open the IGOCentrafuseHelperApps.reg in your favorite text editor
    Modify the Registry Values to suit your setup
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\IGOCFMONITOR]
    "left"="0"
    "right"="800"
    "top"="0"
    "bottom"="100"
    "zone2enable"="1"
    "left2"="780"
    "right2"="800"
    "top2"="500"
    "bottom2"="600"
    "DEBUG"="0"
    "APPPATH"="C:\\Program Files\\iGo8_PC\\iGOZoomer_109.exe"
    "APPNAME"="iGO Zoomer 1.0.9 - www.cybersuricate.com"
    "APPWORKINGDIR"="C:\\Program Files\\iGo8_PC"
    left, right, top, bottom define a rectangular area of the screen that will allow defocusing IE
    make them the coordinated of the area at the top of the screen you may or maynot want to
    Include the Close botton in this to do se set zone2enable=1 and left2, right2, top2, bottom2.
    This Reg file is set correctly for Centrafuse running in 800x600.
    Debug just enables some debugging info so leave at 0 unless you have issues.
    APPPATH is the full path to the Executable that launches IGO
    APPWORKINGDIR is the working directory for IGO
    APPNAME is the programs title bar text. Use ShowTitleApp Utility for programs that hide the
    title bar like IGO. The Example uses a value for IGOZoomer V 1.0.9. The ShowTitleApp.exe will
    display the Title of the Active window 3 Seconds After you press OK. Just end task it once you
    have the required information.
    Once you set the registry. Install the Regfile.
    Open Centrafuse and minimise IGOCentrafuseHelper.exe will not continue running if Centrafuse is not running.
    Test the Program Click IGOLauncher.exe. IGO Should open also check the taskmanager
    for IGOCentrafuseHelper.exe.
    If that works move a window over the top of IGO click the IGOLauncher.exe again and
    IGO should become visable again. This will verify the APPNAME registry key is correct
    if it is not set corectly IGO will open twice.
    Now create a Icon/Button in centrafuse that links to IGOLauncher.exe
    Enjoy.
    Any problems post on the forum.
    http://www.mp3car.com/vbulletin/cf-p...entrafuse.html
    Последний раз редактировалось Sergleo69; 30.10.2008 в 22:19.
    По умолчанию Re: Плагин iGO8
    Интересно.
    Модератор Аватар для vladsmir
    И в чем отличие от "стандартной" процедуры с игозумером? Я вчера эту тему смотрел, на предмет встраивания гармина, но так и не понял что к чему. Помогите, кто силен в английском.
