Страница 1 из 28 123456711 ... ПоследняяПоследняя
Показано с 1 по 10 из 278
Тема: Centrafuse 2.1
    Продвинутый Аватар для RGrin
    По умолчанию Centrafuse 2.1
    Вышла новая версия.
    Version 2.1.1210
    This version will work as a full install or an upgrade if you are running Centrafuse 2.0.806.
    We are initially releasing this update to the forums only before posting it on the web site.
    IF YOU DO NOT NEED ANY OF THE FIXES OR UPDATES IN THIS NEW RELEASE, WE ADVISE YOU WAIT UNTIL IT IS OFFICIALLY AVAILABLE ON THE WEB SITE.
    ** PLEASE READ - IMPORTANT IMPORTANT IMPORTANT - PLEASE READ **
    This version includes a new version of the license manager. You will be required to re-enter your serial, so deactivate your license from your current running version first before installing this update.
    See here for instructions on how to deactivate your license: How to deactivate your license
    Download the update from the link below. Make sure CF is closed, run the installer. An upgrade will be performed if Centrafuse 2.0.806 is currently installed.
    2.1.1210 RELEASE
    Centrafuse 2.1.1210 is the first update to the final 2.0 release (2.0.806), and contains many small bug fixes and enhancements. We anticipate there may be some arising issues due to some core code changes, please install and use this update keeping in mind this is a pre-release to a soon-to-come Version 2.2 in the coming months, and then 3.0 sometime next year.
    UPDATE 2.1
    The Centrafuse 2.1 SDK is now available in the Developers section of your My Account page. The SDK provides: (UPDATE: Will be available SOON after 2.1 release)
    New Delphi.NET example source code
    Latest CFPlugin.dll - Exposes Centrafuse Interfaces and Classes for Plugin Development
    Aura and Onyx PSD Skin packages.
    2 easy-to-understand examples in 4 different languages (C#, VB, C++, and (new) Delphi) including VS2005 Solution and Project files
    A functional CentraFlash Plugin including source code for developing Flash applications that can communicate with Centrafuse
    RadioModule example (HQCT)
    Updated, easy-to-read documentation, in CHM and HTML format
    3rd party apps
    ** NEW in 2.1.1210 ** DVD MODULE
    The DVD Module has been rewritten to use low level DirectX calls. This should improve performance and heavily improve ease of getting DVD to run correctly on various systems. However, this is an initial release of this code and it should be expected that there will be some new DVD issues surfacing. We will work with users to resolve these as soon as possible once reported.
    ** NEW in 2.1.1210 ** AUDIO SYSTEM RESET
    You now have an option to reset the Bass Audio Engine when returning from hibernation/standby. This should clear up many audio issues if having them on resume from standby/hibernation, you can turn this option on/off on Page 4 of the Audio/Video settings by toggling the "Reset Audio on Resume" option.
    ** NOTE for 2.1.1210 ** HQCT-eA CODE HAS BEEN REMOVED FROM HQCT RADIO PLUGIN
    We have removed the turning on/off of the HQCTeA amplifier in the HQCT radio module. We will be adding HQCTeA related code in a seperate plugin, for much better control of the amp, in the near future.
    REMEMBER!!! LOGS FOR SYSTEM REPORTS ARE OFF BY DEFAULT!!!
    Log writing by Centrafuse is now OFF by default. If experiencing issues with Centrafuse, and you need to submit a bug report with a system report, you will have to enable the logs in settings now. General Centrafuse logging (most important) is in General Settings, Bluetooth logging is in Phone settings, SatRadio logging and OBDII logging are in their respective settings screens. All log settings are advanced settings. You can also enable all logs by passing the -logevents command line parameter to centrafuse on startup, which will override whatever you have set in settings for the various logs.
    REMEMBER!!! NEW COMMAND LINE PARAMETER TO USE WHEN CREATING BUG REPORTS
    We have added a new cmd line param, "-disable3rdplugins" (w/o the quotes), which will, when passed, cause all 3rd party plugins not supported by Flux to not be loaded. This will be useful for users to see if any of their 3rd party plugins are causing issues with their centrafuse installs. It will also be required to be used after the official 2.0 release when submitting bug reports, more info on that coming soon.
    Вся информация тут.
    Скачать можно тут.
    Последнее обновление тут.
    Тут лежат клавы Ru-En и En-Ru
    Последний раз редактировалось RGrin; 04.03.2009 в 03:36.
    По умолчанию Re: Centrafuse 2.1
    качаю...
    С запускалкой от предыдущей версии работает.
    Ищу 10 отличий =)
    Ищу 10 отличий =)
    Лучше больше - приятных и полезных.
    А ставить ее как обновление, или как новый продукт?
    Спасибо.
    Судя по описанию решено много проблем.
    Буду качать. А ланчер с этой версией работает?
    написано же выше, что работает
    я скачал, но пока на большом
    Обалдеть. В "огороде" уже к новой версии все есть.
    Киньте ключик пожалуйста а то старый не работает.
    Раздаю временно
    Цитата Сообщение от Chip
    Раздаю временно
    Спасибо!
    Успел.
