Показано с 1 по 2 из 2
Древовидный режим
    По умолчанию VGA-RGBs адаптер 2500 руб.
    Specification:
    Technical Parameter:
    1. Input Power: DC 5V, DC12V
    2. Input Signal:
    640x480 at 60/72/75/85 Hz
    800x600 at 60/75 Hz
    1024x768 at 60/75 Hz
    1280x1024 at 60Hz
    3. Output RGBS(RGB-Sync) Format: 15 KHz column frequency signal
    4. Output Video Signal: CVBS, S-Video
    Technical Features:
    1. 24-bit pro video-processing chip, multi-output video signal
    2. Excellent Color restore, No Bad Pixel, Anti-aliasing
    3. Plug-n-play, Easy to use
    4. Two-mode Switch (NTSC/PAL), adapt to all display devices and TV
    5. OSD menu
    FAQ:
    Q: Display shows abnormal color bar.
    A: Please check the VGA input cable.
    Q: Display shows Black/White or Flash.
    A: You may set the device incorrectly to get a B/W display.
    Please switch NTSC/PAL.
    In PAL mode, the output frequency is 50Hz, which flashes faster than NTSC 60Hz.
    Q: Display Distortion.
    A: The resolution or refresh rate is out of range. Please change the display card setting.
    Suggest resolution is 1024x768 or less and refresh rate is 60Hz.
    Q: Image interference.
    A: Please check if the power supply is normal or electromagnetic field interference is near.
    Q: S-video/RGBS abnormal output.
    A: Please switch the S-Video/RGBS.
    Продам за ненадобностью.
    Цена 2500р.
    Если что можно вопросы по телефону 8-922-222-22-56 Михаил
    Последний раз редактировалось levsha66; 10.11.2011 в 17:30.
