Показано с 1 по 10 из 11
Тема: AT3IONT-I DELUXE
    Лампочка AT3IONT-I DELUXE
    CPU Intel® CPU on Board
    Integrated Dual-core Intel® Atom™ processor 330
    Chipset NVIDIA ION™ Graphics Processors
    Front Side Bus 533 MHz
    Memory 2 x DIMM, Max. 4 GB, DDR3 1066/800 Non-ECC,Un-buffered Memory
    Dual Channel memory architecture
    Please refer to www.asus.com or user manual for Memory QVL.
    Expansion Slots 1 x PCIe x16
    VGA Integrated NVIDIA ION graphics processor
    Support CUDA technology
    Support PhysX technology
    Supports RGB with max. resolution up to 2048x1536x32Bppx75Hz
    Supports HDMI with max. resolution up to 1920x1080x32Bppx60Hz
    Dual VGA output support: RGB & HDMI
    Storage Southbridge
    4 xSATA 3 Gb/s ports
    LAN Gb LAN
    Audio ALC887 6-Channel (for 6 Channels+2 channel)
    USB 10 USB 2.0/1.1 ports (2 ports at mid-board,8 ports at back panel)
    ASUS Unique Features ASUS CrashFree BIOS 3
    ASUS EZ Flash 2
    ASUS MyLogo 3
    ASUS Express Gate
    Home Theater Gate
    ASUS Q-FAN
    Stack Cool3+
    AI NET2
    Back Panel I/O Ports 1 x D-Sub
    1 x PS/2 Keyboard
    1 x HDMI
    1 x S/PDIF Out (optical)
    1 x LAN(RJ45) port
    6 x USB 2.0/1.1
    6 -Channel Audio I/O
    1 x BlueTooth
    1 x 2-CH RCA AUDIO
    WiFi 802.11b/g/n
    1 x DC
    Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
    1 x COM port header
    1 x CPU Fan Connector & controller
    1 x Chassis Fan connector & controller
    1 x Power Fan connector
    1 x Front Panel connector
    1 x High Definition front panel audio connector
    BIOS 8 Mb Flash ROM , AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI v2.0a
    Accessories User's manual
    1 x I/O Shield
    2 x SATA cable(s)
    90W Adaptor & Power Cord
    1 x 4-pin to SATA Power cabel
    Remote Controller & Receiver
    WifFi Antenna
    Support Disc Drivers
    ASUS PC Probe II
    Anti-virus software (OEM version)
    ASUS Update
    User's Manual
    Form Factor Mini ITX Form Factor
    6.75 inch x 6.75 inch ( 17.1 cm x 17.1 cm )
    По умолчанию Re: AT3IONT-I DELUXE
    На Украине 150 баксов за неделюксовую версию. Нет вайфая, блютуса и прочих приблуд. Чистая мать:
    Думаю делюкс будет баксов 200 стоить... что неконкурентно с теми же Zotac IONITX
    в описании есть информация о том, что в ней встроенный блок питания. Не значит ли это, что вкорячить специальный автомобильный БП не получится?
    Заранее спасибо всем откликнувшимся за ответ.
    Продвинутый Аватар для spol81
    Судя по фото его там нет.
    так судя по фото там и АТХ-разъема тоже нет
    Юзер
    отоно чё.
    смутила фотка в посте http://www.compcar.ru/forum/showpost...69&postcount=2
    ну тогда так http://carmonitor.ru/ru/dcdcusb-p-121.html
    отоно чё.
    Чпасиба за ответ, вариянт не устраивает, а жаль (мамка-то какая сладкая)
    это другие материнки, обратите внимание на название (версия DELUXE), отличия.... да их много...
