Specification:
Technical Parameter:
1. Input Power: DC 5V, DC12V
2. Input Signal:
640x480 at 60/72/75/85 Hz
800x600 at 60/75 Hz
1024x768 at 60/75 Hz
1280x1024 at 60Hz
3. Output RGBS(RGB-Sync) Format: 15 KHz column frequency signal
4. Output Video Signal: CVBS, S-Video
Technical Features:
1. 24-bit pro video-processing chip, multi-output video signal
2. Excellent Color restore, No Bad Pixel, Anti-aliasing
3. Plug-n-play, Easy to use
4. Two-mode Switch (NTSC/PAL), adapt to all display devices and TV
5. OSD menu
FAQ:
Q: Display shows abnormal color bar.
A: Please check the VGA input cable.
Q: Display shows Black/White or Flash.
A: You may set the device incorrectly to get a B/W display.
Please switch NTSC/PAL.
In PAL mode, the output frequency is 50Hz, which flashes faster than NTSC 60Hz.
Q: Display Distortion.
A: The resolution or refresh rate is out of range. Please change the display card setting.
Suggest resolution is 1024x768 or less and refresh rate is 60Hz.
Q: Image interference.
A: Please check if the power supply is normal or electromagnetic field interference is near.
Q: S-video/RGBS abnormal output.
A: Please switch the S-Video/RGBS.
Продам за ненадобностью.
Цена 2500р.
Если что можно вопросы по телефону 8-922-222-22-56 Михаил
