Уважаемый Chip!!!
Вот нашел инфу на mp3car, может она мне как-то поможет подключить хотя бы ноутбук? - сам не могу до конца понять что нужно сделать:
the Kenwood needs a +/- mixed sync at TTL level TTL level is 5v peak to peak
RGBs and RGBS are different standards but offten get confused RGBs is Scart RGB and it uses a combined sync it is a composite video signal and a normal sync frequency signal combined I think the voltage is around 7v but don't quote me on the 7 volts I am not really sure
RGBS sync is horizontal and vertical sync mixed at TTL level or 5v peak to peak
RGsB is sync on green it's the same sync signal as RGBS but the sync is mixed in the Green signal
the Kenwood displays need RGBS +/- TTL Level sync at 1Khz the input is a CGA input is a very old computer video standard invented by IBM back when they made computers now they only sell them it was the first color computer video standard
Keep me posted about what converter you find and where that will work with your Xbox as more info becomes available about hooking up to a Kenwood I am going to keep adding it to my tutorial
