Commell LV-673
Intel Pentium M processor with Intel 915GM & ICH6M
dual channel DDR2 400/ 533 MHz SDRAM up to 2GB
Intel GMA 900 technology
Intel 915GM integrated
18-bit LVDS and analog TV-out interface
Onboard PCI-Express 16x and Mini-PCI socket
Support CompactFlash and PCMCIA on solder side
6 x USB2.0 , 2 x RS232 , 2 x SATA, 1 x SPDIF , 1 x IrDA , 1 x GPIO
Commell LV-671
Intel® Centrino™ Mobile Platform
Intel® Pentium® M Processor
On-die 1 MB L2 Cache, 400 MHz FSB
1 GBytes DDR266/333 SDRAM / ECC
Intel Extreme Graphics 2 Technology
Multiple Display LVDS / DVI / HDTV
Intel PRO/1000 GbE Interface
Intel PRO/Wireless WLAN 802.11a/b
5.1 Channel & S/P DIF AC97 3D Audio
Mini-PCI, PCMCIA PC Card Interface
Hi-Speed USB 2.0 with 480 Mbps
IDE-based CompactFlash Interface
Compact Size @ 170 x 170 mm (L x W)
i-Base MB879
Intel® Pentium® M, ATI Radeon Express Mini ITX Motherboard
Mini ITX (170mm X 170mm)
ATI Radeo Express 200 (RC410MD) Chipset,
Supports Intel® Pentium® M/ Celeron® M, up to 2.26GHz
Built-in VGA, ATi M10 graphic core, support CRT, TV out and LVDS
10/100 LAN and PCI Express Gigabit LAN controller
DDR2 socket support up to 1GB memory
Digital I/O, Serial ATA, 1394, one PCI slot
Six USB ports, four COM ports
i-Base MB890
Intel 855GME Pentium M mini-itx motherboard
Mini- ITX Form Factor (170mm X 170mm)
Intel® 855GME or 852GM Chipset
Supports Pentium® M / Celeron® M processors
Up to 2.0GHz, 400MHz FSB
1x DR DIMM, max. 1GB
Integrated VGA, shared memory, CRT/LVDS/DVI
Integrated 10/100 BaseT Ethernet
Watchdog timer, 6x USB 2.0 ports, PCI slot
Mini-PCI slot, optional 2x 1394
i-Base MB896
Socket 479 Pentium® M Mini-ITX Motherboard with Intel® 915GM Chipset
Supports up to 2.26GHz, 400MHz/533MHz FSB
One DDR2 SDRAM DIMM, Max. 1GB memory
Onboard 10/100 BaseT and Marvell PCI-Express Gigabit LAN
Intel® 915GM VGA for CRT / 18-bit dual channel LVDS
2x SATA, 6x USB 2.0, 2x COM, Watchdog timer, 1394
1x PCI, 1x MiniPCI, 1xPCI-E(x1) slots, optional single/dual DVI card
AOpen i915GMt
Intel Pentium M CPU (Dothan) Socket 479 533MHz
Chhipset: Intel 915GM Intel ICH6-M
Main Memory: Realtek (RTM865) Dual Channel Mode Support : DDRII 667/533/400 DDRII DIMM x 2 DIMM Type : 128/256/512MB & 1GB Max Memory : 2GB
Graphics: Integrated VGA Engine in chipset
IDE: Integrated ATA100 and Serial ATA Controller
LAN: Realtek Gigabit PCI LAN Chip
Sound: Azalia 7.1 channel codec on-board (ALC880) Integrated in chipset
Slots: PCI x 1
Storage & Back Pannel I/O: Adapter Connector x 1, IDE Channel : ATA100 x 1, Serial ATA Channel x 2, PS/2, Keyboard x 1, PS/2 Mouse x 1, DVI Connector x 1, VGA Port x 1, Standard Video x 1, 1394 Port x 1, LAN Port x 1, USB Port x 4, COM Port x 1, Line_In x 1, MC_In x 1, Speaker_Out x 1, Center/Subwoofer x 1, Rear Surround x 1, Side Surround x 1
On Board Connector: 4-pin 12V Connector x 1, CPU FAN x 1, System FAN x 1, Power Temperature Connector x 1, Front Panel x 1, USB Port x 4, COM Port x 1, IEEE 1394 x 1, S/PDIF x 1, CD_IN x 1
BIOS: Award PnP 4Mb Flash ROM BIOS
Form Factor: Flex ATX (mini ITX): 170 mm x 170 mm
iGoLogic Inc MBI3368G
Processor - Compatible with Intel® Pentium M and Celeron-M LV (Low Voltage) /ULV (Ultra Low Voltage) CPU’s
Chipset - Intel® 852GM + ICH*4
System Memory - 1 x 184-pin DDR DIMM memory up to 1GB
VGA - Integrated in Intel® 852GM GMCH, max. up to 64MB frame buffer sharing system memory
Expansion Slots - 1 PCI
Onboard IDE - 2 x PATA-100 IDE
Onboard LAN - Dual LAN (One Gigabit & One Fast)
Onboard Audio - AC’97 codec audio
Onboard LVDS Out - 2 x LVDS display out
Back Panel I/O - 1 PS2 mouse port - 1 PS2 keyboard port - 2 RJ-45 LAN port - 3 Serial port - 4 USB 2.0 ports - 1 VGA port - 3 Audio jacks: line-out, line-in and mic-in
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports - 1 COM port - 1 Front-panel audio connector (Mic-in and Line-out) - 1 FIR connector - 2 Fan connectors: CPU/Sys FAN - 2 LVDS connectors - ATX power connector
Ответить с цитированием
