Показано с 1 по 2 из 2
    По умолчанию GPS GPRS TLT-1B Automobile Tracker
    TLT-1B Automobile Tracker(900/1800)
    The TLT-1 GPS/GSM Tracker is a vehicle remote position device with build-in GPS and GSM/GPRS modules. It is a small size, high accuracy remote location tracking device. Based on GPS satellite, it provides accurate position information under dynamic conditions. Personal remote position device transmit the longitude and latitude coordinate to authorized cell phone. You can use these features for a security purpose and other purpose which needs
    remote positioning such as asset protection and tracking. (82mm*45mm*18mm)
    1.Built-in SIRF Star? Chipset, excellent for fixing the position even at a weak signal status. Work well even in areas with limited sky view like urban canyons.
    2. Built-in GSM/GPRS module, support 4-frequency GSM 900/1800 MHz (850/1900 Optional), working all over the world.
    3. Support voice call.
    4. Support SMS communication or GPRS TCP connection.
    5. Get the position information via mobile phone SMS, or examine the path on the Internet.
    6. The available SMS takes the control command change tracing function or switch GPS.
    7.Support establishes three telephone numbers. SOS button send out exact location for immediate rescue/action.
    8. One key for easily use.
    9. The major technological index of the device is in conformity with the international standard of GSM mobile phone.
    10. Portable, compact size, low power design.
    11. Support cut-off electricity and oil function and recovery command
    12. Support electronic fence function
    в комплекте сам прибор в аллюм.корпусе, внешние GSM и GPS антены с кабелем, провод питания, SOS и рабочего режима.
    встраиваемый прибор.
    передача сообщений по:
    1. по запросу по смс он передаст свои координаты
    2. через GPRS по TCP-IP
    3. по SOS-входу, или например от сработавшей сигнализации
    4. по наличию напряжения на входе напр. от бензонасоса или ключа зажигания...
    ведет лог по питанию, и по сигналам входных линий.
    все базовые настройки через смс
    отображение трека в автоматическом режиме в GoogleEarth, там надо прописать сервер как источник GPS сигнала, и все пойдет по TCP-IP.
    цена была 4400р (138$) стала 3700р.
    в связи с отсутствием человека по продажам, цена на регистратор и трекеры снижается на его оплату - на 700р.
    минус тот что теперь только самовывоз, и по почте посылать нет времени.
ID:	5504   Нажмите на изображение для увеличения.
ID:	5505   Нажмите на изображение для увеличения.
    Последний раз редактировалось A.V.K.; 21.09.2009 в 00:48.
