Ребят, нашёл тут даташит на свой моник, но чвот не разберусь, куда синхру впаять.
LCD Module Connector
FPC Down Connect , 30 Pins , Pitch : 0.5 mm
Pin No Symbol I/O Description Remark
1 GND - Ground for logic circuit
2 VCC I Supply voltage of logic control circuit for gate driver Note 5-3
3 NC - No connection
4 VEE I Negative power for gate driver Note 5-4
5 NC - No connection
6 VGH I Positive power for gate driver Note 5-5
7 NC - No connection
8 STVD I/O Vertical start pulse
9 STVU I/O Vertical start pulse
Note 5-1
10 CKV I Shift clock for gate driver
11 U/D I Up / Down Control for gate driver Note 5-1
12 OE3 I Output enable for gate driver
13 OE2 I Output enable for gate driver
14 OE1 I Output enable for gate driver
15 VCOM I Common electrode voltage
16 STHL I/O Start pulse for source driver Note 5-2
17 VSS2 - Ground for analog circuit
18 VR I Video Input R
19 VG I Video Input G
20 VB I Video Input B
21 VSS1 - Ground for digital circuit
22 VDD2 I Supply power for analog circuit Note 5-6
23 CPH1 I Sampling and shift clock for source driver
24 CPH2 I Sampling and shift clock for source driver
25 CPH3 I Sampling and shift clock for source driver
26 VDD1 I Supply power for digital circuit Note 5-7
27 R/L I Left / Right Control for source driver Note 5-2
28 NC I No Connection
29 OEH I Output enable for source driver
30 STHR I/O Start pulse for source driver Note 5-2
Note 5-1
U/D STVD STVU scanning direction
Vcc Input output down to up
GND Output input up to down
Note 5-2
R/L STHL STHR scanning direction
Vcc output input left to right
GND input output right to left
