// lcd pins connected to corresponding lcd pins
#define RS (4)
#define RESET (17)
#define CS (16)
#define CLK (13)
#define DAT (11)
void setup() {
   // set  output pins
   pinMode(RESET, OUTPUT);
   digitalWrite(RESET,LOW);
   pinMode(CS, OUTPUT);
   digitalWrite(CS,HIGH);
   pinMode(RS, OUTPUT);
   pinMode(CLK, OUTPUT);
   pinMode(DAT, OUTPUT);
    * init starts here
   delay(100); // wait a bit for everything to settle down... who knows
   digitalWrite(CS, HIGH);
   digitalWrite(RS, HIGH);
   digitalWrite(RESET, LOW);
   delay(50);
   digitalWrite(RESET, HIGH);
   delay(50);
   digitalWrite(CS,LOW);
   unsigned char LCD_init_masiv[70][3] ={
                                      {0x74,0x00,0x00}, //1 block
                                      {0x76,0x00,0x01},
                                      {0x74,0x00,0x07},
                                      {0x76,0x00,0x00},
                                      {0x74,0x00,0x02},
                                      {0x76,0x04,0x00},
                                      {0x74,0x00,0x04},
                                      {0x76,0x00,0x00},
                                      {0x74,0x00,0x0C},
                                      {0x76,0x00,0x01},
                                      {0x74,0x00,0x0D},
                                      {0x76,0x06,0x16},
                                      {0x74,0x00,0x1E},
                                      {0x76,0x10,0x10}, //2 block
                                      {0x74,0x00,0x03},
                                      {0x76,0x00,0x0C},
                                      {0x74,0x00,0x0E},
                                      {0x76,0x2D,0x1F},
                                      {0x74,0x00,0x0D},
                                      {0x76,0x06,0x16},
                                      {0x74,0x00,0x01},
                                      {0x76,0x02,0x15},
                                      {0x74,0x00,0x0F},
                                      {0x76,0x00,0x00},
                                      {0x74,0x00,0x0B},
                                      {0x76,0x00,0x00},
                                      {0x74,0x00,0x11},
                                      {0x76,0x00,0x00}, //3 block
                                      {0x74,0x00,0x06},
                                      {0x76,0x00,0x00},
                                      {0x74,0x00,0x05},
                                      {0x76,0x00,0x30},
                                      {0x74,0x00,0x14},
                                      {0x76,0xAF,0x00},
                                      {0x74,0x00,0x15},
                                      {0x76,0x00,0x00},
                                      {0x74,0x00,0x16},
                                      {0x76,0x83,0x00},
                                      {0x74,0x00,0x17},
                                      {0x76,0xAF,0x00},
                                      {0x74,0x00,0x20},
                                      {0x76,0x00,0x00}, //4 block
                                      {0x74,0x00,0x30},
                                      {0x76,0x00,0x00},
                                      {0x74,0x00,0x31},
                                      {0x76,0x04,0x00},
                                      {0x74,0x00,0x32},
                                      {0x76,0x02,0x07},
                                      {0x74,0x00,0x33},
                                      {0x76,0x07,0x00},
                                      {0x74,0x00,0x34},
                                      {0x76,0x00,0x05},
                                      {0x74,0x00,0x35},
                                      {0x76,0x07,0x03},
                                      {0x74,0x00,0x36},
                                      {0x76,0x07,0x07}, //5 blocl
                                      {0x74,0x00,0x37},
                                      {0x76,0x00,0x07},
                                      {0x74,0x00,0x3A},
                                      {0x76,0x12,0x00},
                                      {0x74,0x00,0x3B},
                                      {0x76,0x00,0x09},
                                      {0x74,0x00,0x07},
                                      {0x76,0x00,0x05},
                                      {0x74,0x00,0x07},
                                      {0x76,0x00,0x25},
                                      {0x74,0x00,0x07},
                                      {0x76,0x00,0x27},
                                      {0x74,0x00,0x07},
                                      {0x76,0x00,0x37}
   int i;
   for(i=0;i<=69;i++){
   shiftOut(DAT, CLK, MSBFIRST, (LCD_init_masiv[i][0] >> 8));
   shiftOut(DAT, CLK, MSBFIRST, LCD_init_masiv[i][0]);
   shiftOut(DAT, CLK, MSBFIRST, (LCD_init_masiv[i][1] >> 8));
   shiftOut(DAT, CLK, MSBFIRST, LCD_init_masiv[i][1]);
   shiftOut(DAT, CLK, MSBFIRST, (LCD_init_masiv[i][2] >> 8));
   shiftOut(DAT, CLK, MSBFIRST, LCD_init_masiv[i][2]);
   // were done, display doesnt need to listen anymore
   pinMode(13, OUTPUT);
void loop() {
   // blink onboard led to signal end of init
   digitalWrite(13,HIGH);
   delay(250);
   digitalWrite(13,LOW);
   delay(250);
 У меня Arduino UNO, питание для подсветки беру внешнее 10В, а для питания самого дисплея эти же 10В через стабилизатор 3,3В. Согласование с Arduino через делители.
