Имеется плата видеорегистратора на 4 канала с АППАРАТНЫМ сжатием (не потребовалась), готов продать за $100, хотя можем потороговаться Предлагайте, если есть интерес.
PCI-E 4 Channel D1 Express CCTV DVR Capture Card ZS-6404IE
Features & Specifications:
- Cable: one VGA15 connection lines (8lines: 4V,4A)
- Video input : 4 channels, full real time, full D1
- Audio input: 4 channels
- TV Output: RCA Connector x 1
- Video resources
PAL: 100 frames with All Full D1 (preview and record)
NTSC: 120 frames with All Full D1 (preview and record)
- Video sampling resolution
PAL: Full D1 (704x576)
NTSC: Full D1 (704x480)
- Video/Audio processing chip (Techwell TW6864)
10 bit video ADC with 4H filter and color correction and AGC function.
- Video display output
VGA preview display (whole screen or picture division)
TV output monitors screening (more channels patrol in turn)
- Compression ways
H.264 / MPEG 4 / WMV3 compression formats for selection; outside hangs CODEC user-defined compression format as well.
- Storage mode
HV codes stream (can play together with J8000 hardware card format and can choose AVI document mode (the biggest single doc. is 2G);
- Alarm input/output
20-bit input/output are matchable with GPIO trigger mode and Alarm may take another card or alarm boxes
- Cradle head / Vidicon control
Each channel can process the control of cradle head/DV, support many protocols.
- Long-distance transmit
The client-side and IE-side can monitor 32 channels in long-distance, control cradle head/DV in long-distance as well, supporting voice talkback.
- Network
Support TCP/IP and UDP transmit, support many network accesses such as PSTN/ISDN/DDN/ADSL/LAN/WWW.
- Hardware platform and operating system
Intel 845/848/865/915/945/965 chips; C4 above 2.0G; 32 or 64 bit CPU; 4 dicaryon or double dicaryon is better. (24 channels CIF in real-time need P4 3.0G or dicaryon above 2.8G).Windows 2000/XP/VISTA/7 operating systems
The basic function of the software:
- The function of the software is powerful; the single machine can kinescope and preview 32 channels Video.
- Date,time and each Vidicon can searches in time apart.
- Can add OSD/LOGO, can accomplish the camera function( JPG/BMP)
- Moving sense Vidicon and give an alarm(external access to box of give an alarm/voice/email/short message)
- Many kinescope mode: dynamic kinescope, sense kinescope, timing kinescope and continual kinescope.
- Several external controls: cradle- head, Vidicon, electrical source, rain bush and focalize camera lens.
- Set up several clients’ purview management, support set up user operating purview.
- Can accomplish several channels of IE preview and control, and supply power function of operating system for client-side
