Показано с 1 по 10 из 52
Тема: Citroen Xsara
Древовидный режим
    По умолчанию Re: Citroen Xsara
    Схема проекта, фотки железа и скриншоты оболочки
    http://www.flickr.com/photos/69338318@N06
    Рассчитана на подключение к магнитоле, заточенной под синтезатор частоты и аудиопроцессор TDA7318, радио реализовано на LM7001
    Скетч для Teensy 2.0 ++
    Код HTML:
    #include <IRremote.h>
    #include <OneWire.h>
    #include <DallasTemperature.h>
    #include <Wire.h>
    #include <SPI.h>
    #include <MeetAndroid.h>
    #define HEATER1 19
    //#define HEATER1 6
    #define HEATER2 41
    #define AMP_ON 16
    #define AUDIO_MUTE 17
    #define AD_SELECT 20
    // Data wire is plugged into pin 25 on the Arduino
    #define ONE_WIRE_BUS 25
    const int RECV_PIN = 26;
    #define FAN_DIRECTION_PWM 27
    #define POWER_SWITCH 38
    #define AUDIO_ON 44
    #define ACC 45
    #define CLIMATE_POWER 42
    #define CLIMATE_REC 43
    #define DS1307_I2C_ADDRESS 0x68
    #define TDA7318_I2C_ADDRESS 0x44
    #define TDA_SW1 0x58
    #define TDA_SW2 0x59
    #define TDA_SW3 0x5A
    #define TDA_SW4 0x5B
    // LM pins
    #define LM_CE 14 //LM7001 PIN3
    #define LM_CL 13 //LM7001 PIN4
    #define LM_DA 12 //LM7001 PIN5
    // LM delay in microsec
    #define LM_DELAY 2
    #define RADIO_MIN_FREQUENCY 880
    #define RADIO_MAX_FREQUENCY 1080
    DeviceAddress intTempSensor = { 0x28, 0x44, 0x0A, 0xD8, 0x02, 0x00, 0x00, 0x58 };
    DeviceAddress extTempSensor = { 0x28, 0xA8, 0xE4, 0x7D, 0x02, 0x00, 0x00, 0x5C };
    DeviceAddress hlTempSensor = { 0x28, 0x7C, 0xDF, 0xD7, 0x02, 0x00, 0x00, 0x02 };
    DeviceAddress hrTempSensor = { 0x28, 0xB6, 0x1A, 0x7E, 0x02, 0x00, 0x00, 0x98 };
    byte climateTempMap[] = {255,255,255,255,255,255,255,255,255,255,
                             255,255,255,255,255,255,255,255,225,200,
                             175,150,130,105,80,60,40,0x00};
    byte climateFanMap[] = {0,16,32,48,64,80,96,112,128,144,
                            160,176,192,208,224,255};
    byte climateDirectionMap[] = {0,0,64,128,255};
    byte volMap[] = {0x3F,0x3D,0x3B,0x39,0x37,0x35,0x33,0x31,
                      0x2F,0x2D,0x2B,0x29,0x27,0x25,0x23,0x21,
                      0x1F,0x1D,0x1B,0x19,0x17,0x15,0x13,0x11,
                      0x0F,0x0D,0x0B,0x09,0x07,0x05,0x03,0x00};
    byte lfAttMap[] = {0x9F,0x9D,0x9B,0x99,0x97,0x95,0x93,0x91,
                       0x8F,0x8D,0x8B,0x89,0x87,0x85,0x83,0x80};
    byte rfAttMap[] = {0xBF,0xBD,0xBB,0xB9,0xB7,0xB5,0xB3,0xB1,
                       0xAF,0xAD,0xAB,0xA9,0xA7,0xA5,0xA3,0xA0};
    byte lrAttMap[] = {0xDF,0xDD,0xDB,0xD9,0xD7,0xD5,0xD3,0xD1,
                       0xCF,0xCD,0xCB,0xC9,0xC7,0xC5,0xC3,0xC0};
    byte rrAttMap[] = {0xFF,0xFD,0xFB,0xF9,0xF7,0xF5,0xF3,0xF1,
                       0xEF,0xED,0xEB,0xE9,0xE7,0xE5,0xE3,0xE0};
    byte bassMap[] = {0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x6F,
                      0x6E,0x6D,0x6C,0x6B,0x6A,0x69,0x68};
    byte trebleMap[] = {0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x7F,
                        0x7E,0x7D,0x7C,0x7B,0x7A,0x79,0x78};
    byte currentVolume = 16;
    byte currentHeaterOff1 = 0;
    byte currentHeaterOn1 = 0;
    byte currentHeaterOff2 = 0;
    byte currentHeaterOn2 = 0;
    int heaterTimer1 = 0;
    int heaterTimer2 = 0;
    OneWire oneWire(ONE_WIRE_BUS);
    DallasTemperature sensors(&oneWire);
    IRrecv irrecv(RECV_PIN);
    decode_results results;
    MeetAndroid meetAndroid;
    HardwareSerial Uart = HardwareSerial();
    void setup() {
      Uart.begin(9600);
      Serial.begin(9600);
      setCallbacks();
      initTempSensors();
      initTda();
      initLM();
      initAd();
      initHeaters();
      initIR();
      pinMode(CLIMATE_POWER, OUTPUT);
      pinMode(CLIMATE_REC, OUTPUT);
      pinMode(POWER_SWITCH, OUTPUT);
      digitalWrite(POWER_SWITCH, LOW);
      pinMode(FAN_DIRECTION_PWM, OUTPUT);
      pinMode(AMP_ON, OUTPUT);
      pinMode(AUDIO_ON, OUTPUT);
      pinMode(AUDIO_MUTE, OUTPUT);
    void loop()
      meetAndroid.receive(); // you need to keep this in your loop() to receive events
      receiveIR();
      if (heaterTimer1 == 10000) {
        checkHeater1();
        heaterTimer1 = 0;
      if (heaterTimer2 == 15000) {
        checkHeater2();
        heaterTimer2 = 0;
      heaterTimer1++;
      heaterTimer2++;
    void setCallbacks() {
      meetAndroid.registerFunction(getInternalTemperature, 'A'); //Internal temperature: 1
      meetAndroid.registerFunction(setAudioBalance, 'B'); //Audio balance: 0-15
      meetAndroid.registerFunction(setClimatePower, 'C'); //Climate power: 1-ON, 0-OFF
      meetAndroid.registerFunction(setClimateFanDirection, 'D'); //Climate fan direction: 1-direction 1, 2-direction 2, 3-direction 3, 4-direction 4
      meetAndroid.registerFunction(getExternalTemperature, 'E'); //External temperature: 1
      meetAndroid.registerFunction(setClimateFanSpeed, 'F'); //Climate fan speed: 0-15
      meetAndroid.registerFunction(setHeaterOnTemperature1, 'G'); //Heater temp 1 ON: 25-ON, 0-OFF
      meetAndroid.registerFunction(setHeaterOnTemperature2, 'H'); //Heater temp 2 ON: 25-ON, 0-OFF
      meetAndroid.registerFunction(setClimateRecirculation, 'I'); //Climate internal recirculation: 1-ON, 0-OFF
      meetAndroid.registerFunction(setAudioBass, 'J'); //Audio bass: 0-14
      meetAndroid.registerFunction(setAudioTreble, 'K'); //Audio treble: 0-14
      meetAndroid.registerFunction(setAudioRearLeftVolume, 'L'); //Audio rear left volume: 0-15
      meetAndroid.registerFunction(setAudioMute, 'M'); //Audio mute: 1-ON, 0-OFF
      meetAndroid.registerFunction(setHeaterOffTemperature1, 'N'); //Heater temp 1 OFF: 25-OFF, 0-OFF
      meetAndroid.registerFunction(setHeaterOffTemperature2, 'O'); //Heater temp 2 OFF: 25-OFF, 0-OFF
      meetAndroid.registerFunction(setPowerState, 'P'); //Power state: 1-ON, 0-OFF
      meetAndroid.registerFunction(setRadioFrequency, 'R'); //Radio frequency: (880-1080)-ON, 0-OFF
      meetAndroid.registerFunction(setAudioSource, 'S'); //Audio source: 2-radio, 3-music
      meetAndroid.registerFunction(setClimateTemperature, 'T'); //Climate temperature: 18-26
      meetAndroid.registerFunction(getCarVoltage, 'U'); //Car voltage: 1
      meetAndroid.registerFunction(setAudioVolume, 'V'); //Audio volume: 0-31
      meetAndroid.registerFunction(setAudioRearRightVolume, 'X'); //Audio rear right volume: 0-15
      meetAndroid.registerFunction(getHeaterTemperature1, 'Y'); //Heater 1
      meetAndroid.registerFunction(getHeaterTemperature2, 'Z'); //Heater 2
    void initTempSensors() {
      sensors.begin();
      // set the resolution to 9 bit
      sensors.setResolution(intTempSensor, 9);
      sensors.setResolution(extTempSensor, 9);
      sensors.setResolution(hlTempSensor, 9);
      sensors.setResolution(hrTempSensor, 9);
    void initTda() {
      sendAudioMute(1);
      sendAudioOn(1);
      delay(3000);
      sendAmpOn(1);
      Wire.begin(); // join i2c bus (address optional for master)
      sendAudioVolume(16);
      sendAudioLFAttenuator(15);
      sendAudioRFAttenuator(15);
      sendAudioLRAttenuator(15);
      sendAudioRRAttenuator(15);
      sendAudioSwitch(3);
      sendAudioBass(7);
      sendAudioTreble(7);
      sendAudioMute(0);
    void initLM() {
      pinMode(LM_CE, OUTPUT);
      pinMode(LM_CL, OUTPUT);
      pinMode(LM_DA, OUTPUT);
    void initAd(){
      pinMode(AD_SELECT, OUTPUT);
      SPI.begin();
    void initHeaters() {
      pinMode(HEATER1, OUTPUT);
      pinMode(HEATER2, OUTPUT);
    void initIR() {
      irrecv.enableIRIn();
      irrecv.blink13(true);
    void receiveIR() {
      if (irrecv.decode(&results)) {
        char buf[50];
        sprintf(buf, "IR:%u", results.value);
        meetAndroid.send(buf);
        irrecv.resume();
    void checkHeater1() {
      if (currentHeaterOff1 != 0 && currentHeaterOn1 != 0) {
        sensors.requestTemperaturesByAddress(hlTempSensor);
        float tempC = sensors.getTempC(hlTempSensor);
        if (tempC != -127.00) {
          if (tempC > currentHeaterOff1) {
            digitalWrite(HEATER1, LOW);
          if (tempC < currentHeaterOn1) {
            digitalWrite(HEATER1, HIGH);
      else {
    void checkHeater2() {
      if (currentHeaterOff2 != 0 && currentHeaterOn2 != 0) {
        sensors.requestTemperaturesByAddress(hrTempSensor);
        float tempC = sensors.getTempC(hrTempSensor);
          if (tempC > currentHeaterOff2) {
            digitalWrite(HEATER2, LOW);
          if (tempC < currentHeaterOn2) {
            digitalWrite(HEATER2, HIGH);
      else {
    void writeI2c(byte address, byte value) {
      Wire.beginTransmission(address);
      Wire.send(value);
      Wire.endTransmission();
    void sendAudioMute(byte value) {
      digitalWrite(AUDIO_MUTE, value == 1 ? HIGH : LOW);
    void sendAmpOn(byte value) {
      digitalWrite(AMP_ON, value == 1 ? HIGH : LOW);
    void sendAudioOn(byte value) {
      digitalWrite(AUDIO_ON, value == 1 ? HIGH : LOW);
    void sendAudioVolume(byte value) {
      if (value > 31) return;
      currentVolume = value;
      writeI2c(TDA7318_I2C_ADDRESS, volMap[value]);
    void sendAudioLFAttenuator(byte value) {
      if (value > 15) return;
      writeI2c(TDA7318_I2C_ADDRESS, lfAttMap[value]);
    void sendAudioRFAttenuator(byte value) {
      writeI2c(TDA7318_I2C_ADDRESS, rfAttMap[value]);
    void sendAudioLRAttenuator(byte value) {
      writeI2c(TDA7318_I2C_ADDRESS, lrAttMap[value]);
    void sendAudioRRAttenuator(byte value) {
      writeI2c(TDA7318_I2C_ADDRESS, rrAttMap[value]);
    void sendAudioBass(byte value) {
      if (value > 14) return;
      writeI2c(TDA7318_I2C_ADDRESS, bassMap[value]);
    void sendAudioTreble(byte value) {
      writeI2c(TDA7318_I2C_ADDRESS, trebleMap[value]);
    void sendAudioSwitch(byte value) {
      switch (value) {
        case 1:
          writeI2c(TDA7318_I2C_ADDRESS, TDA_SW1);
          break;
        case 2:
          writeI2c(TDA7318_I2C_ADDRESS, TDA_SW2);
          break;
        case 3:
          writeI2c(TDA7318_I2C_ADDRESS, TDA_SW3);
          break;
        case 4:
          writeI2c(TDA7318_I2C_ADDRESS, TDA_SW4);
          break;
    void sendRadioFrequency(int frequency, boolean power) {
      frequency += 107;
      digitalWrite(LM_CE, HIGH);
      writeLM(byte(frequency));
      writeLM(byte(frequency >> 8));
      writeLM((power == true) ? 135 : 71);
      digitalWrite(LM_CE, LOW);
    void writeLM(byte bytes) {
      int d;
      int d1;
      delayMicroseconds(LM_DELAY);
      for (int x=0; x <= 7; x++) {
      // Set DA
        d = bytes >> 1;
        d1 = d << 1;
        digitalWrite(LM_DA, bytes == d1 ? LOW : HIGH);
        // Make CL
        digitalWrite(LM_CL, HIGH);
        digitalWrite(LM_CL, LOW);
        bytes = bytes >> 1;
    void getInternalTemperature(byte flag, byte numOfValues)
      sensors.requestTemperaturesByAddress(intTempSensor);
      float tempC = sensors.getTempC(intTempSensor);
      meetAndroid.send(tempC == -127.00 ? 0 : tempC);
    void setAudioBalance(byte flag, byte numOfValues)
      int value = meetAndroid.getInt();
      sendAudioLFAttenuator(value);
      sendAudioRFAttenuator(15 - value);
    void setClimatePower(byte flag, byte numOfValues)
      digitalWrite(CLIMATE_POWER, meetAndroid.getInt() == 1 ? HIGH : LOW);
    void setClimateFanDirection(byte flag, byte numOfValues)
      if (value < 1 && value > 4) value = 1;
      analogWrite(FAN_DIRECTION_PWM, climateDirectionMap[value]);
    void getExternalTemperature(byte flag, byte numOfValues)
      sensors.requestTemperaturesByAddress(extTempSensor);
      float tempC = sensors.getTempC(extTempSensor);
    void setClimateFanSpeed(byte flag, byte numOfValues)
      if (value < 0) value = 0;
      if (value > 15) value = 15;
      digitalPotWrite(0, climateFanMap[value]);
    void getHeaterTemperature1(byte flag, byte numOfValues)
    void getHeaterTemperature2(byte flag, byte numOfValues)
    void setHeaterOnTemperature1(byte flag, byte numOfValues)
      currentHeaterOn1 = meetAndroid.getInt();
    void setHeaterOffTemperature1(byte flag, byte numOfValues)
      currentHeaterOff1 = meetAndroid.getInt();
    void setHeaterOnTemperature2(byte flag, byte numOfValues)
      currentHeaterOn2 = meetAndroid.getInt();
    void setHeaterOffTemperature2(byte flag, byte numOfValues)
      currentHeaterOff2 = meetAndroid.getInt();
    void setClimateRecirculation(byte flag, byte numOfValues)
      digitalWrite(CLIMATE_REC, (meetAndroid.getInt() == 1) ? HIGH : LOW);
    void setAudioBass(byte flag, byte numOfValues)
      sendAudioBass(meetAndroid.getInt());
    void setAudioTreble(byte flag, byte numOfValues)
      sendAudioTreble(meetAndroid.getInt());
    void setAudioRearLeftVolume(byte flag, byte numOfValues)
      sendAudioLRAttenuator(meetAndroid.getInt());
    void setAudioMute(byte flag, byte numOfValues)
      sendAudioMute(meetAndroid.getInt());
    void setPowerState(byte flag, byte numOfValues)
      digitalWrite(POWER_SWITCH, (meetAndroid.getInt() == 1) ? HIGH : LOW);
    void setRadioFrequency(byte flag, byte numOfValues)
      int frequency = meetAndroid.getInt();
      if (frequency == 0) {
        sendRadioFrequency(frequency, false);
      else if (frequency >= RADIO_MIN_FREQUENCY && frequency <= RADIO_MAX_FREQUENCY){
        sendRadioFrequency(frequency, true);
    void setAudioSource(byte flag, byte numOfValues)
      sendAudioSwitch(meetAndroid.getInt());
    void setClimateTemperature(byte flag, byte numOfValues)
      if (value < 18) value = 0;
      if (value > 26) value = 27;
      digitalPotWrite(1, climateTempMap[value]);
    void digitalPotWrite(byte address, byte value){
      digitalWrite(AD_SELECT, LOW);
      SPI.transfer(address);
      SPI.transfer(value);
      digitalWrite(AD_SELECT, HIGH);
    void getCarVoltage(byte flag, byte numOfValues)
      float R1 = 9930.0;
      float R2 = 970.0;
      int value = analogRead(ACC);
      meetAndroid.send(((value * 5.0) / 1024.0) / (R2 / (R1 + R2)));
    void setAudioVolume(byte flag, byte numOfValues)
      sendAudioVolume(meetAndroid.getInt());
    void setAudioRearRightVolume(byte flag, byte numOfValues)
      sendAudioRRAttenuator(meetAndroid.getInt());
    В новой версии (в работе) Ethernet модуль заменит Bluetooth, а планшет Huawei S7 - на Android TV BOX (http://www.pandawill.com/x1-mini-and...ck-p49624.html)
    Железо будет доработано, скетч и оболочка будут модернизированы.
    Последний раз редактировалось s.m.; 30.11.2011 в 04:26.
