Страница 4 из 6 ПерваяПервая 123456 ПоследняяПоследняя
Показано с 31 по 40 из 60
  1. #31
    По умолчанию Re: Программатор из Arduino
    GND, +5v, D10, D11, D12, D13
    // this sketch turns the Arduino into a AVRISP
    // using the following pins:
    // 10: slave reset
    // 11: MOSI
    // 12: MISO
    // 13: SCK
    // Put an LED (with resistor) on the following pins:
    // 9: Heartbeat - shows the programmer is running
    // 8: Error - Lights up if something goes wrong (use red if that makes sense)
    // 7: Programming - In communication with the slave
    // October 2010 by Randall Bohn
    // - Write to EEPROM > 256 bytes
    // - Better use of LEDs:
    // -- Flash LED_PMODE on each flash commit
    // -- Flash LED_PMODE while writing EEPROM (both give visual feedback of writing progress)
    // - Light LED_ERR whenever we hit a STK_NOSYNC. Turn it off when back in sync.
    // October 2009 by David A. Mellis
    // - Added support for the read signature command
    // February 2009 by Randall Bohn
    // - Added support for writing to EEPROM (what took so long?)
    // Windows users should consider WinAVR's avrdude instead of the
    // avrdude included with Arduino software.
    // January 2008 by Randall Bohn
    // - Thanks to Amplificar for helping me with the STK500 protocol
    // - The AVRISP/STK500 (mk I) protocol is used in the arduino bootloader
    // - The SPI functions herein were developed for the AVR910_ARD programmer
    // - More information at http://code.google.com/p/mega-isp
    #define SCK 13
    #define MISO 12
    #define MOSI 11
    #define RESET 10
    #define LED_HB 9
    #define LED_ERR 8
    #define LED_PMODE 7
    #define PROG_FLICKER true
    #define HWVER 2
    #define SWMAJ 1
    #define SWMIN 18
    // STK Definitions
    #define STK_OK 0x10
    #define STK_FAILED 0x11
    #define STK_UNKNOWN 0x12
    #define STK_INSYNC 0x14
    #define STK_NOSYNC 0x15
    #define CRC_EOP 0x20 //ok it is a space...
    void pulse(int pinint times);
    void setup() {
    Serial.begin(19200);
    pinMode(LED_PMODEOUTPUT);
    pulse(LED_PMODE2);
    pinMode(LED_ERROUTPUT);
    pulse(LED_ERR2);
    pinMode(LED_HBOUTPUT);
    pulse(LED_HB2);
    int error=0;
    int pmode=0;
    // address for reading and writing, set by 'U' command
    int here;
    uint8_t buff[256]; // global block storage
    #define beget16(addr) (*addr * 256 + *(addr+1) )
    typedef struct param {
    uint8_t devicecode;
    uint8_t revision;
    uint8_t progtype;
    uint8_t parmode;
    uint8_t polling;
    uint8_t selftimed;
    uint8_t lockbytes;
    uint8_t fusebytes;
    int flashpoll;
    int eeprompoll;
    int pagesize;
    int eepromsize;
    int flashsize;
    parameter;
    parameter param;
    // this provides a heartbeat on pin 9, so you can tell the software is running.
    uint8_t hbval=128;
    int8_t hbdelta=8;
    void heartbeat() {
      if (
    hbval 192hbdelta = -hbdelta;
      if (
    hbval 32hbdelta = -hbdelta;
    hbval += hbdelta;
    analogWrite(LED_HBhbval);
    delay(40);
    void loop(void) {
    // is pmode active?
    if (pmodedigitalWrite(LED_PMODEHIGH);
      else
    digitalWrite(LED_PMODELOW);
    // is there an error?
    if (errordigitalWrite(LED_ERRHIGH);
      else
    digitalWrite(LED_ERRLOW);
    // light the heartbeat LED
    heartbeat();
      if (
    Serial.available()) {
    avrisp();
    uint8_t getch() {
      while(!
    Serial.available());
      return
    Serial.read();
    void fill(int n) {
      for (
    int x 0nx++) {
    buff[x] = getch();
    #define PTIME 30
    void pulse(int pinint times) {
      do {
    digitalWrite(pinHIGH);
    delay(PTIME);
    digitalWrite(pinLOW);
    delay(PTIME);
      while (
    times--);
    void prog_lamp(int state) {
      if (
    PROG_FLICKER)
    digitalWrite(LED_PMODEstate);
    void spi_init() {
    uint8_t x;
    SPCR 0x53;
    x=SPSR;
    x=SPDR;
    void spi_wait() {
      do {
      while (!(
    SPSR & (<< SPIF)));
    uint8_t spi_send(uint8_t b) {
    uint8_t reply;
    SPDR=b;
    spi_wait();
    reply SPDR;
      return
    reply;
    uint8_t spi_transaction(uint8_t auint8_t buint8_t cuint8_t d) {
    uint8_t n;
    spi_send(a);
    n=spi_send(b);
    //if (n != a) error = -1;
    n=spi_send(c);
      return
    spi_send(d);
    void empty_reply() {
      if (
    CRC_EOP == getch()) {
    Serial.print((char)STK_INSYNC);
    Serial.print((char)STK_OK);
      } else {
    error++;
    Serial.print((char)STK_NOSYNC);
    void breply(uint8_t b) {
      if (
    Serial.print((char)b);
      else {
    error++;
    void get_version(uint8_t c) {
      switch(
    c) {
      case
    0x80:
    breply(HWVER);
        break;
      case
    0x81:
    breply(SWMAJ);
        break;
      case
    0x82:
    breply(SWMIN);
        break;
      case
    0x93:
    breply('S'); // serial programmer
    break;
      default:
    breply(0);
    void set_parameters() {
    // call this after reading paramter packet into buff[]
    param.devicecode buff[0];
    param.revision buff[1];
    param.progtype buff[2];
    param.parmode buff[3];
    param.polling buff[4];
    param.selftimed buff[5];
    param.lockbytes buff[6];
    param.fusebytes buff[7];
    param.flashpoll buff[8];
    // ignore buff[9] (= buff[8])
      // following are 16 bits (big endian)
    param.eeprompoll beget16(&buff[10]);
    param.pagesize beget16(&buff[12]);
    param.eepromsize beget16(&buff[14]);
    // 32 bits flashsize (big endian)
    param.flashsize buff[16] * 0x01000000
    buff[17] * 0x00010000
    buff[18] * 0x00000100
    buff[19];
    void start_pmode() {
    spi_init();
    // following delays may not work on all targets...
    pinMode(RESETOUTPUT);
    digitalWrite(RESETHIGH);
    pinMode(SCKOUTPUT);
    digitalWrite(SCKLOW);
    delay(50);
    digitalWrite(RESETLOW);
    delay(50);
    pinMode(MISOINPUT);
    pinMode(MOSIOUTPUT);
    spi_transaction(0xAC0x530x000x00);
    pmode 1;
    void end_pmode() {
    pinMode(MISOINPUT);
    pinMode(MOSIINPUT);
    pinMode(SCKINPUT);
    pinMode(RESETINPUT);
    pmode 0;
    void universal() {
    int w;
    uint8_t ch;
    fill(4);
    ch spi_transaction(buff[0], buff[1], buff[2], buff[3]);
    breply(ch);
    void flash(uint8_t hiloint addruint8_t data) {
    spi_transaction(0x40+8*hilo
    addr>>0xFF
    addr 0xFF,
    data);
    void commit(int addr) {
      if (
    PROG_FLICKERprog_lamp(LOW);
    spi_transaction(0x4C, (addr >> 8) & 0xFFaddr 0xFF0);
      if (
    PROG_FLICKER) {
    delay(PTIME);
    prog_lamp(HIGH);
    //#define _current_page(x) (here & 0xFFFFE0)
    int current_page(int addr) {
      if (
    param.pagesize == 32) return here 0xFFFFFFF0;
      if (
    param.pagesize == 64) return here 0xFFFFFFE0;
      if (
    param.pagesize == 128) return here 0xFFFFFFC0;
      if (
    param.pagesize == 256) return here 0xFFFFFF80;
      return
    here;
    void write_flash(int length) {
    fill(length);
      if (
    Serial.print((charSTK_INSYNC);
    Serial.print((charwrite_flash_pages(length));
      } else {
    error++;
    Serial.print((charSTK_NOSYNC);
    uint8_t write_flash_pages(int length) {
    int x 0;
    int page current_page(here);
      while (
    length) {
        if (
    page != current_page(here)) {
    commit(page);
    flash(LOWherebuff[x++]);
    flash(HIGHherebuff[x++]);
    here++;
    commit(page);
      return
    STK_OK;
    #define EECHUNK (32)
    uint8_t write_eeprom(int length) {
    // here is a word address, get the byte address
    int start here 2;
    int remaining length;
      if (
    length param.eepromsize) {
    error++;
        return
    STK_FAILED;
      while (
    remaining EECHUNK) {
    write_eeprom_chunk(startEECHUNK);
    start += EECHUNK;
    remaining -= EECHUNK;
    write_eeprom_chunk(startremaining);
      return
    STK_OK;
    // write (length) bytes, (start) is a byte address
    uint8_t write_eeprom_chunk(int startint length) {
    // this writes byte-by-byte,
      // page writing may be faster (4 bytes at a time)
    fill(length);
    prog_lamp(LOW);
      for (
    int x 0lengthx++) {
    int addr start+x;
    spi_transaction(0xC0, (addr>>8) & 0xFFaddr 0xFFbuff[x]);
    delay(45);
    prog_lamp(HIGH);
      return
    STK_OK;
    void program_page() {
    char result = (charSTK_FAILED;
    int length 256 getch() + getch();
    char memtype getch();
    // flash memory @here, (length) bytes
    if (memtype == 'F') {
    write_flash(length);
        return;
      if (
    memtype == 'E') {
    result = (char)write_eeprom(length);
        if (
    Serial.print(result);
        } else {
    error++;
        return;
    Serial.print((char)STK_FAILED);
      return;
    uint8_t flash_read(uint8_t hiloint addr) {
      return
    spi_transaction(0x20 hilo 8,
    addr >> 8) & 0xFF,
    addr 0xFF,
    0);
    char flash_read_page(int length) {
      for (
    int x 0lengthx+=2) {
    uint8_t low flash_read(LOWhere);
    Serial.print((charlow);
    uint8_t high flash_read(HIGHhere);
    Serial.print((charhigh);
    here++;
      return
    STK_OK;
    char eeprom_read_page(int length) {
    // here again we have a word address
    int start here 2;
      for (
    int x 0lengthx++) {
    int addr start x;
    uint8_t ee spi_transaction(0xA0, (addr >> 8) & 0xFFaddr 0xFF0xFF);
    Serial.print((charee);
      return
    STK_OK;
    void read_page() {
    char result = (char)STK_FAILED;
      if (
    CRC_EOP != getch()) {
    error++;
        return;
      if (
    memtype == 'F'result flash_read_page(length);
      if (
    memtype == 'E'result eeprom_read_page(length);
      return;
    void read_signature() {
      if (
    error++;
        return;
    uint8_t high spi_transaction(0x300x000x000x00);
    uint8_t middle spi_transaction(0x300x000x010x00);
    Serial.print((charmiddle);
    uint8_t low spi_transaction(0x300x000x020x00);
    Serial.print((charSTK_OK);
    int avrisp() {
    uint8_t datalowhigh;
    uint8_t ch getch();
      switch (
    ch) {
      case
    '0'// signon
    error 0;
    empty_reply();
        break;
      case
    '1':
        if (
    getch() == CRC_EOP) {
    Serial.print("AVR ISP");
        break;
      case
    'A':
    get_version(getch());
        break;
      case
    'B':
    fill(20);
    set_parameters();
    empty_reply();
        break;
      case
    'E'// extended parameters - ignore for now
    fill(5);
    empty_reply();
        break;
      case
    'P':
    start_pmode();
    empty_reply();
        break;
      case
    'U'// set address (word)
    here getch() + 256 getch();
    empty_reply();
        break;
      case
    0x60//STK_PROG_FLASH
    low getch();
    high getch();
    empty_reply();
        break;
      case
    0x61//STK_PROG_DATA
    data getch();
    empty_reply();
        break;
      case
    0x64//STK_PROG_PAGE
    program_page();
        break;
      case
    0x74//STK_READ_PAGE 't'
    read_page();
        break;
      case
    'V'//0x56
    universal();
        break;
      case
    'Q'//0x51
    error=0;
    end_pmode();
    empty_reply();
        break;
      case
    0x75//STK_READ_SIGN 'u'
    read_signature();
        break;
    // expecting a command, not CRC_EOP
      // this is how we can get back in sync
    case CRC_EOP:
    error++;
        break;
    // anything else we will return STK_UNKNOWN
    default:
    error++;
        if (
    CRC_EOP == getch())
    Serial.print((char)STK_UNKNOWN);
        else
    Последний раз редактировалось Chip; 27.05.2011 в 02:08.
  2. #32
    Пользователь Аватар для ASSAD
    будем разбираться. что то тяжело мне даются микроконтроллеры""!!!!
    Последний раз редактировалось ASSAD; 27.05.2011 в 02:16.
    GigaByte GA-H55N-USB3(rev. 1.0)
    Intel Core i3-540
    m4-atx
  3. #33
    Может, не твоё?
    По схеме выше я прошивал atmega8. Работает.
  4. #34
    Вопрос на засыпку. А можно ли ардуиной шить/читать SPI Flash 25хххх?
  5. #35
    Это зависит от программы используемой на компьютере avrdude
    Вот список микросхем которые можно прошить
    #define ATTINY10 0x10
    #define ATTINY11 0x11
    #define ATTINY12 0x12
    #define ATTINY15 0x13
    #define ATTINY13 0x14
    #define ATTINY22 0x20
    #define ATTINY26 0x21
    #define ATTINY28 0x22
    #define ATTINY2313 0x23
    #define AT90S1200 0x33
    #define AT90S2313 0x40
    #define AT90S2323 0x41
    #define AT90S2333 0x42
    #define AT90S2343 0x43
    #define AT90S4414 0x50
    #define AT90S4433 0x51
    #define AT90S4434 0x52
    #define ATMEGA48 0x59
    #define AT90S8515 0x60
    #define AT90S8535 0x61
    #define AT90C8534 0x62
    #define ATMEGA8515 0x63
    #define ATMEGA8535 0x64
    #define ATMEGA8 0x70
    #define ATMEGA88 0x73
    #define ATMEGA168 0x86
    #define ATMEGA161 0x80
    #define ATMEGA163 0x81
    #define ATMEGA16 0x82
    #define ATMEGA162 0x83
    #define ATMEGA169 0x84
    #define ATMEGA323 0x90
    #define ATMEGA32 0x91
    #define ATMEGA64 0xA0
    #define ATMEGA103 0xB1
    #define ATMEGA128 0xB2
    #define AT90CAN128 0xB3
    #define AT86RF401 0xD0
    #define AT89START 0xE0
    #define AT89S51 0xE0
    #define AT89S52 0xE1
    Но при желании можно самому написать программу и скетч для прошивки Flash микросхем
    Последний раз редактировалось Chip; 07.09.2011 в 10:44.
  6. #36
    Ниасилю на текущем этапе развития
    Собрал "шило" для LPT. Работает. Но хотелось по-универсальнее что-то...
  7. #37
    Модератор Аватар для XsanderS
    А че ATMEGA 328 с помощью avrdude не прошить? Кстати в IDE arduino есть функция в закладках Tools типа BrunBootloader. Я так понемаю достаточно воткнуть чистую атмегу в Arduino, соеденить разем х3 с пинами Atmega, выбрать в Tools->Board нужный борт, в данном случае Duemilanove or Nano /w Atmega 328 и остается только хлопать в ладоши? или я не правильно понял?
    Последний раз редактировалось XsanderS; 29.10.2011 в 01:26.
    Мой проект
  8. #38
    Это так?
    А то я моск себе уже вскрыл????????????????????????
  9. #39
    А то покупаешь за 1300 у нас в ниф-нипе, тдык она ещё и не шьнтся!!!!!
  10. #40
    Нфига это схема не работает!!!!!!!!!!!!!!!!!!!!!!!!
    тыщы раз роверял!!!!!!!!!!!!!!!!!
