Это QRPp CW-маяк, работающий на 160/80/40-метровом диапазоне. Автор скетча Клименко Максим.
Есть желание доработать этот скетч для вставки GPS-координат в текст посылки и параллельного логирования координат и времени фиксации на SD-карту.
Что скажите господа?
Код:
// Arduino simply CW beacon
// (c) 2012 Max Klimenko
// emaster [at] mail.ru
// Beacon message
const char message[] = "VVV CQ CQ CQ DX DE BEACON BAND 40M 8000KHZ";
// Period of single point (ms)
const int point_time = 80;
// Carrier frequency divider.
// Carrier freq. (MHz) = 16 / (2 * (1 + freq_div))
const unsigned char freq_div = 1;
struct s_abc
        char letter;
        char sign[7];
const s_abc abc[] = {
        'A',".-", 'B',"-...", 'W',".--", 'G',"--.", 'D',"-..",
        'E',".", 'V',"...-", 'Z',"--..", 'I',"..",
        'J',".---", 'K',"-.-", 'L',".-..", 'M',"--", 'N',"-.",
        'O',"---", 'P',".--.", 'R',".-.", 'S',"...",
        'T',"-", 'U',"..-", 'F',"..-.", 'H',"....", 'C',"-.-.",
        'Q',"--.-", 'Y',"-.--", 'X',"-..-", '1',".----",
        '2',"..---", '3',"...--", '4',"....-", '5',".....",
        '6',"-....", '7',"--...", '8',"---..", '9',"----.",
        '0',"-----", '.',"......", ',',".-.-.-", ':',"---...",
unsigned char abc_size = sizeof(abc) / sizeof(abc[0]);
void setup()
  PORTB = 0;
  DDRB |= 1<<1;
  OCR1A = freq_div;
  TCCR1A = 0x48;
  TCCR1B = 0x09;
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
void send_letter(char l)
  if (l == ' ')
    delay(point_time * 7);
    return;
  unsigned char idx = 255;
  for (unsigned char i = 0; i < abc_size; i++)
    if (abc[i].letter == l)
      idx = i;
      break;
  if (idx == 255) return;
  const char *s = abc[idx].sign;
  for (unsigned char c = 0; s[c] != 0; c++)
    char q = s[c];
    DDRB |= 1<<1;
    if (q == '.') delay(point_time);
    else delay(point_time * 3);
    DDRB &= ~(1<<1);
    digitalWrite(13, LOW);   // set the LED off
    delay(point_time);
  delay(point_time * 2);
void loop()
  for (int n = 0; message[n] != 0; n++)
    send_letter(message[n]);
  delay(2000);
