Прошивать мегошилом:
Про зеркалирование - без понятия...
В общем, распаялся, слил прошивку, сравниваю с твоей, курю форумы.
В аттаче оригинальная прошивка CHI MEI 8,9" N089L6-L01
Мысли следующие:
Моя прошивка (3 части)
==================================================Код:Monitor Model name............... KX Manufacturer............. KXR Plug and Play ID......... KXR0017 Serial number............ 0000000000001 Manufacture date......... 2003, ISO week 3 Filter driver............ None ------------------------- EDID revision............ 1.2 Input signal type........ Analog 0.700,0.000 (0.7V p-p) Sync input support....... Separate Display type............. RGB color Screen size.............. 300 x 230 mm (14,9 in) Power management......... Standby, Suspend, Active off/sleep Extension blocs.......... None ------------------------- DDC/CI................... n/a
==================================================Код:Monitor Model name............... 32V3H-H6A Manufacturer............. RTK Plug and Play ID......... RTK4C54 Serial number............ 1 Manufacture date......... 2007, ISO week 12 Filter driver............ None ------------------------- EDID revision............ 1.3 Input signal type........ Digital (DVI) Color bit depth.......... Undefined Display type............. RGB color Screen size.............. 700 x 390 mm (31,5 in) Power management......... Standby Extension blocs.......... 1 (CEA-EXT) ------------------------- DDC/CI................... n/a
Твоя прошивкаКод:Monitor Model name............... KX Manufacturer............. KXR Plug and Play ID......... KXR0017 Serial number............ 0000000000001 Manufacture date......... 2003, ISO week 3 Filter driver............ None ------------------------- EDID revision............ 1.2 Input signal type........ Analog 0.700,0.000 (0.7V p-p) Sync input support....... Separate Display type............. RGB color Screen size.............. 300 x 230 mm (14,9 in) Power management......... Standby, Suspend, Active off/sleep Extension blocs.......... None ------------------------- DDC/CI................... n/a
Код:Monitor Manufacturer............. Chi Mei Plug and Play ID......... CMO0109 Data string.............. N089L6-L01 Serial number............ n/a Manufacture date......... 2008, ISO week 31 Filter driver............ None ------------------------- EDID revision............ 1.3 Input signal type........ Digital Color bit depth.......... Undefined Display type............. RGB color Screen size.............. 210 x 120 mm (9,5 in) Power management......... Not supported Extension blocs.......... None ------------------------- DDC/CI................... n/aКод:Monitor Manufacturer............. Chi Mei Plug and Play ID......... CMO0109 Data string.............. N089L6-L01 Serial number............ n/a Manufacture date......... 2008, ISO week 31 Filter driver............ None ------------------------- EDID revision............ 1.3 Input signal type........ Digital Color bit depth.......... Undefined Display type............. RGB color Screen size.............. 210 x 120 mm (9,5 in) Power management......... Not supported Extension blocs.......... None ------------------------- DDC/CI................... n/a1. У тебя все входы стали Digital. Я пока не знаю, на что это может повлиятьКод:Monitor Manufacturer............. Chi Mei Plug and Play ID......... CMO0109 Data string.............. N089L6-L01 Serial number............ n/a Manufacture date......... 2008, ISO week 31 Filter driver............ None ------------------------- EDID revision............ 1.3 Input signal type........ Digital Color bit depth.......... Undefined Display type............. RGB color Screen size.............. 210 x 120 mm (9,5 in) Power management......... Not supported Extension blocs.......... None ------------------------- DDC/CI................... n/a
2. У тебя все Power management......... Not supported. Как у тебя сейчас себя ведет моник при уходе в спячку?
3. У тебя есть синий экран при отсутствии сигнала? Если да, то как его убрать? //если вдруг знаешь//
4. Хочу проверить софт-управление яркостью подсветки, непосредственно ламп.
5. Сейчас на работе, моник дома. У нас такое можно? (думаю да) http://www.compcar.ru/forum/showpost...16&postcount=3
6. Даташит на контроллер http://monitor.espec.ws//files/2660_107.pdf
Последний раз редактировалось Wanderer; 07.11.2011 в 20:21.
Буду краток! Все работает!
Синий экран вырубается сам по тайм-ауту. Кста, это, вполне возможно, включается в инженерном меню. Постараюсь не забыть - сфотаю свои настройки.
У меня в проигрывателе есть фича - выключить монитор. Вызывается стандартная функция API. Оно тоже работает. Т.е. Power Managment работает нормально.
То, что все входы стали "дигитал", глубоко пофигу, т.к. подключение идет по аналогу.
зы: собсна, а чего теоретизировать? Залей мою прошу да потести.
Минимум у двух человек она работает.
Последний раз редактировалось BlkDem; 07.11.2011 в 12:50.
Т.е. при нажатии у тебя зажигается секунд на 10 синий экран, потом гаснет?У меня в проигрывателе есть фича - выключить монитор. Вызывается стандартная функция API. Оно тоже работает.
подправил немного первое сообщение. (пп 5 и 6)
Нет, при прямом вызове, экран тухнет сразу, т.к. мы прямо говорим ему - OFF.
Когда же пропадает сигнал, секунд 5 синий экран с надписью "No Signal" и отключение.
По поводу джига. А нах..!? (простите мне мой французский)
Я не пойму тебя, чего ты хошь от монитора? Натив выставляется, управление питанием работает, режимы на месте...
ОК. Последний вопрос:
Какой плеер это делает?Нет, при прямом вызове, экран тухнет сразу, т.к. мы прямо говорим ему - OFF.
Даташиты N089L6:
чистый даташит N089L6-L01, EDIDов нет (вместо значений TBD)
http://www.avidia.com.tw/docs/product/N089L6-L01.pdf
N089L6-L01 Approval to Asus http://wenku.baidu.com/view/0e532501...789ebc993.html
Approval to Dell N089L6-L02
http://wendang.baidu.com/view/5f9e44...3f90f1c81.html
Последний раз редактировалось Wanderer; 07.11.2011 в 20:32.
Мой плеер. Не проси - не дам. Он сильно заточенный
EDID брался именно с даташита, и совпадает бит в бит.
Опаньки. Ты уверен, что у тебя L02?
Тайминги не совпадают с L01
Последний раз редактировалось BlkDem; 07.11.2011 в 14:38.
домой доберусь проверю все внимательно.
NirCMD monitor off в Windows 7 вызывает синий экран NoSignal на 10 сек.
То же и через встроенные функции в винде.
Поэтому и спросил про плеер.
у меня L01.
Проверил свои ссылки более внимательно, переправил как надо.
Сверил твою прошивку с даташитом, все 1-в-1. Сейчас буду заливать.
Ты в эти EDIDы можешь написать вообще что угодно
Реально аналоговая часть правится непосредственно в дампе.
EDID я просто для правильности оригинальный вставил.
