Показано с 11 по 20 из 25
Древовидный режим
    По умолчанию Системные платы для процессоров Amd
    Jetway J7F3 Series
    SiS 741CX Northbridge + SiS 964 Southbridge Chipsets
    Support Socket-462 AMD Geode NX processor
    Support Front Side Bus 133MHz
    Single Channel DDR2 400 Memory DIMM
    Support 2 Serial ATA Devices with RAID 0, 1
    Support 2xAD Connector With Expansion Daughter-boards
    Ethernet LAN Supported
    AC’97 6 Channel Audio CODEC
    VIA VT6307S IEEE1394a Controller for J7F3E
    17 x 17CM Mini-ITX Form Factor
    i-Base MB740
    AMD Geode NX Mini ITX Motherboard
    Socket A for AMD Geode NX processors
    Up to 1.4GHz speed, 133MHz FSB
    DDR DIMM x 1, Max. 1GB, DDR266/333
    Onboard 10/100 and Realtek 8110S Gigabit Ethernet
    Integrated SiS 741CX VGA, supports CRT
    Optional LVDS/TV-out, DVI/CRT2 MAGP VGA cards
    2 x SATA, 6 x USB 2.0, 2 x COM, Watchdog timer
    1x PCI, 1x Mini PCI, 1x MicroAGP, optional 1394
    Albatron KI51PV-754
    AMD Athlon™ 64 / Sempron™ /Turion™ 64 Processors
    Socket 754 with Hyper Transport?800+ MHz
    1 DDR333/400 Memory Sockets
    Integrated NVIIDA GeForce 6150 Graphics Engine.
    Provides DVI / D-SUB / HDTV-out (by optional cable) interface.
    Realtek AC97 6 channel
    Marvell 10/100 Mbps LAN PHY / Marvell Gbit LAN & NVIDIA Active Armor
    1*PCI Solt
    4 SATA II Channels, SATA RAID 0,1,5& 0+1
    2 ATA133 Channels
    Dual BIOS (Second BIOS by Optional ABS Card)
    8 USB 2.0/1.1 Ports (4 ports by optional cable)
    Последний раз редактировалось Chip; 22.08.2007 в 22:39.
