Показано с 1 по 10 из 25
    По умолчанию Системные платы для процессоров Amd
    Jetway J7F3 Series
    SiS 741CX Northbridge + SiS 964 Southbridge Chipsets
    Support Socket-462 AMD Geode NX processor
    Support Front Side Bus 133MHz
    Single Channel DDR2 400 Memory DIMM
    Support 2 Serial ATA Devices with RAID 0, 1
    Support 2xAD Connector With Expansion Daughter-boards
    Ethernet LAN Supported
    AC’97 6 Channel Audio CODEC
    VIA VT6307S IEEE1394a Controller for J7F3E
    17 x 17CM Mini-ITX Form Factor
    i-Base MB740
    AMD Geode NX Mini ITX Motherboard
    Socket A for AMD Geode NX processors
    Up to 1.4GHz speed, 133MHz FSB
    DDR DIMM x 1, Max. 1GB, DDR266/333
    Onboard 10/100 and Realtek 8110S Gigabit Ethernet
    Integrated SiS 741CX VGA, supports CRT
    Optional LVDS/TV-out, DVI/CRT2 MAGP VGA cards
    2 x SATA, 6 x USB 2.0, 2 x COM, Watchdog timer
    1x PCI, 1x Mini PCI, 1x MicroAGP, optional 1394
    Albatron KI51PV-754
    AMD Athlon™ 64 / Sempron™ /Turion™ 64 Processors
    Socket 754 with Hyper Transport?800+ MHz
    1 DDR333/400 Memory Sockets
    Integrated NVIIDA GeForce 6150 Graphics Engine.
    Provides DVI / D-SUB / HDTV-out (by optional cable) interface.
    Realtek AC97 6 channel
    Marvell 10/100 Mbps LAN PHY / Marvell Gbit LAN & NVIDIA Active Armor
    1*PCI Solt
    4 SATA II Channels, SATA RAID 0,1,5& 0+1
    2 ATA133 Channels
    Dual BIOS (Second BIOS by Optional ABS Card)
    8 USB 2.0/1.1 Ports (4 ports by optional cable)
    Последний раз редактировалось Chip; 22.08.2007 в 22:39.
    По умолчанию Re: Системные платы для Amd
    MSI Fuzzy 690T
    System
    • Processor: AMD Socket AM2(AM2+) Athlon 64X2 / Athlon 64 / Sempron
    • Chipset: ATI RS690T + SB600
    • Memory: 200pin DDR2 667/800 SO-DIMM Socket X2 up to 4GB
    • BIOS: AWARD 512KB Flash ROM
    • Graphic Engine: ATI Radeon Xpress 1270
    I/O
    • Display: D-Sub, HDMI, LVDS, HDTV
    • Super I/O: Winbond 83627 DHG (Watch Dog Timer 255 levels 0~255mS or S)
    • Storage Devices: Ultra DMA 66/100 mode IDE 40 Pin X1, SATA X2, CF Socket X1
    • MIO: RS-232 X 2, FDD X1, PS/2 (K/B X1 Mouse X1)
    • USB: USB 2.0 Port X8 (Rear I/O X4, Internal pin head x4)
    • Ethernet: Marvell 88E8056 X2, 10/100/1000
    • Expansion Slot: 32-bit PCI, Mini PCI-E
    • Audio / Amplifier: 7.1/5.1 Channels HD Audio/ 6Watt Amplifier
    • Power Source / Form Factor: ATX Power / Mini ITX
    • EMC: CE, FCC Class A, C-Tick, VCCI, BSMI
    Environmental & Dimension
    • Board Dimension: 170mm x 170mm or 6.7in. 6.7in.
    • Operating Temperature: 0~60 °C
    • Operating Humidity: 10%~80% Relative Humidity, non-condensing
    http://www.msicomputer.com/product/p...690T&class=ipc
    :wq
    Хорошая плата.
    А что стоит и где купить?
    Цитата Сообщение от Chip
    Хорошая плата.
    В наличии нигде пока нет
    стоит около $200
    http://price.ru/bin/price/prodlist?c...here=00&sort=1
    :wq
    Модератор Аватар для XsanderS
    У нас уже есть стоит 145,31 €
    Мой проект
    Вспоминаю анекдот времен застоя:
    - Скажите, у вас нет рыбы?
    - У нас нет мяса! рыбы нет в отделе напротив!
    ... у нас тут много чего нет.
    У вас доступны процессоры ADD3800CUBOX (ADD3800IAA5CU) - AMD Athlon™ X2 Dual-Core 3800+ (2Ghz), 35W TDP? Отличный проц для перечисленных тут плат. У нас нет. Нашел только окончившийся аукцион в Украине...
    :wq
    Да уже есть цена вопроса 33,67 € плюс доставка если по германии то примерно 10 €. Когда появился немогу сказать но так как его нет еще на Ebay то похоже примерно 1-3 месяца.
    http://www.perloxx.de/index.php?page...24&ref=froogle
    Последний раз редактировалось XsanderS; 11.07.2008 в 15:33.
    Мой проект
    А чем тебе AMD 64 x2 4050E - 4850E не нравится ? Потребление 45W
    Правда я вчера последние забрал в OLDI .
    А чем тебе AMD 64 x2 4050E не нравится ? Потребление 45W
    Этого нет в списке поддерживаемых MSI Fuzzy 690T
    Из 45-ватных двухядерников остановился пока на BE-2350, доступны.
    :wq
    Ну так это тотже ВЕ только новая серия, а старые ВЕ уже сняты с производства.
