Страница 6 из 10 ПерваяПервая 12345678910 ПоследняяПоследняя
Показано с 51 по 60 из 93
  1. #51
    По умолчанию Re: Управление шаговым двигателем
    Вот что получилось
    #include <Stepper.h>
    #include <EEPROM.h>
    #define motorSteps 24
    #define motorPin1 8
    #define motorPin2 9
    #define motorPin3 10
    #define motorPin4 11
    int switchPin1 = 2;
    int switchPin2 = 4;
    int switchPin3 = 3;
    int switchPin4 = 5;
    int ledPin = 13;
    int x;
    int z;
    int y;
    int addr = 0;
    boolean lastButton1 = LOW;
    boolean currentButton1 = LOW;
    boolean lastButton2 = LOW;
    boolean currentButton2 = LOW;
    boolean lastButton3 = LOW;
    boolean currentButton3 = LOW;
    boolean lastButton4 = LOW;
    boolean currentButton4 = LOW;
    Stepper myStepper(motorSteps, motorPin1,motorPin2,motorPin3,motorPin4);
    pinMode(switchPin1, INPUT);
    pinMode(switchPin2, INPUT);
    pinMode(switchPin3, INPUT);
    myStepper.setSpeed(200);
    boolean debounce1(boolean last)
    boolean current1 = digitalRead(switchPin1);
      if (
    last != current1)
    delay(5);
      return
    current1;
    boolean debounce2(boolean last)
    boolean current2 = digitalRead(switchPin2);
      if (
    last != current2)
    delay(5);
      return
    current2;
    boolean debounce3(boolean last)
    boolean current3 = digitalRead(switchPin3);
      if (
    last != current3)
    delay(5);
      return
    current3;
    boolean debounce4(boolean last)
    boolean current4 = digitalRead(switchPin4);
      if (
    last != current4)
    delay(5);
      return
    current4;
    //EEPROM.write(0, 0);
    x=EEPROM.read(0);
    currentButton1 = debounce1(lastButton1);
          if (
    lastButton1 == LOW && currentButton1 == HIGH && x < 13)
    myStepper.step(-24);
    x = x + 1;
    lastButton1 = currentButton1;
    currentButton2 = debounce2(lastButton2);
          if (
    lastButton2 == LOW && currentButton2 == HIGH && x > 0)
    myStepper.step(24);
    x = x - 1;
    lastButton2 = currentButton2;
    z = 13 - x;
    currentButton3 = debounce3(lastButton3);
          if (
    lastButton3 == LOW && currentButton3 == HIGH)
    myStepper.step(-z*24);
    x = x + z;
    lastButton3 = currentButton3;
    y = x;
    currentButton4 = debounce4(lastButton4);
          if (
    lastButton4 == LOW && currentButton4 == HIGH)
    myStepper.step(y*24);
    x = y - x;
    lastButton4 = currentButton4;
    x = min(x, 13);
    x = max(x, 0);
    EEPROM.write(0, x);
    delay(100);
    Последний раз редактировалось Chip; 16.01.2012 в 19:56.
  2. #52
    Китайцы предлагают контроллер шагового двигателя
    http://item.taobao.com/item.htm?id=13237717196
    Если вот такой мотор на 12В прицепить к этому контроллеру будет ли работать?
    http://item.taobao.com/item.htm?id=12640015828
    Сможет ли этот мотор ~4 кило сдвинуть (все таки винтовая пара - сила) и с какой силой тока примерно?
    Последний раз редактировалось kadushkin; 08.02.2012 в 00:48.
  3. #53
    Потянет
  4. #54
    Chip
    А что действительно такие шаговые двигатели не прожорливые?
    Вроде пишут при 12В всего 0,4А или это номинальный ток
  5. #55
    Это я думаю указан ток без нагрузки, по китайски не понимаю
  6. #56
    Насчет контроллера может этот лучше взять (у первого что я давал на фотке видно кондер не стоит, а место под него есть, как-то стремно)
    http://item.taobao.com/item.htm?id=12466272238
    Только почему-то у него входов для ардуино меньше...
    Вообще-то надо два контроллера, надеюсь выходов на ардуино хватит
    У меня мега, там вроде ШИМ выводы нужны
    Последний раз редактировалось kadushkin; 08.02.2012 в 01:28.
  7. #57
    Одно и тоже, все построено на микросхеме L298N 4 управляющих входа 4 полумостовых выхода
    Последний раз редактировалось Chip; 08.02.2012 в 02:33.
  8. #58
    Спасибо. Буду брать.
  9. #59
    Еще вопрос возник, для начального позиционирования привода в каком-то нулевом положении, что датчик нужно цеплять к движку?
    Ну то есть за ноль что принять?
  10. #60
    Загнать в крайнее положение и от этого положения вести отсчет
