VIA EPIA CN13000
1.3GHz/1.0GHz VIA C7 nanoBGA2 Processor
VIA CN700 North Bridge
VIA VT8237R-Series South Bridge
System Memory -1 DDR2 400/533 DIMM socket, Up to 1GB memory size
Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoding acceleration
Expansion Slots - 1 PCI
Onboard IDE - UltraDMA 133/100/66 Connectors
Onboard LAN - VIA VT6103 LAN Controller
Onboard Audio - VIA VT1618 8-channel AC'97 Codec
Back Panel I/O -1 PS2 mouse port; 1 PS2 keyboard port; 1 Serial port; 1 VGA port; 1 RJ45 port; 4 USB 2.0 ports; 1 RCA port (S/PDIF or TV out); 1 S-Video port; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 4 additional USB 2.0 ports; 2 SATA Connectors; 1 Front-panel audio connector (Mic and Line Out); 1 CIR connector (Switchable for KB/MS); 1 LPT connector; 1 CD-in connector; 2 Fan connectors: CPU/Sys FAN
VIA EPIA EN15000
1.5GHz/1.2GHz VIA C7 nanoBGA2 Processor
System Memory - 1 DDR2 400/533 DIMM socket, Up to 1GB memory size
Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoding acceleration Expansion Slots - 1 PCI
Onboard IDE - 2 UltraDMA 133/100/66 Connectors
Onboard LAN - VIA VT6122 GLAN Controller
Onboard Audio - VIA VT1618 8 channel AC'97 Codec
Onboard 1394 - VIA VT6307S IEEE 1394 Firewire
Back Panel I/O - 1 PS2 mouse port; 1 PS2 keyboard port; 1 Serial port; 1 VGA port; 1 RJ45 port; 4 USB 2.0 ports; 1 RCA port (S/PDIF or TV out); 1 S-Video port; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports; 1 1394 connector for 1 1394 port; 2 SATA Connectors; 1 LPC connector; 1 Front-panel audio connector (Mic and Line Out); 1 Serial port connector for a second com port; 1 CIR connector (Switchable for KB/MS); 1 SIR pin header (IrDA 1.0); 2 Fan connectors: CPU/Sys FAN; 1 SMBUS connector; 1 S/PDIF in connector; 1 S/PDIF out connector; 1 LVDS/TTL/DVI module connector (an add-on card is required); 1 Component (YPbPr) video pin header
VIA EPIA SP13000 and SP8000
VIA C3™/ VIA Eden™ EBGA processor
VIA CN400 North Bridge
System Memory - 1 DDR266/333/400 DIMM socket. Up to 1GB memory size
VGA - Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoder /MPEG-4 Accelerator
Onboard IDE - 2 X UltraDMA 133/100 Connector
Onboard Serial ATA - 2 SATA Connectors
Onboard LAN - VIA VT6103 10/100 Base-T Ethernet PHY
Onboard Audio - VIA VT1617A 6channel AC'97 codec
Back Panel I/O - 1 PS2 mouse port; 1 PS2 keyboard port; 1 RJ-45 LAN port; 1 Serial port; 2 USB 2.0 ports; 1 VGA port; 1 PCA port (SPDIF or TV out); 1 S-video port; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
Onboard I/O Connectors - 3 USB connector for 6additional USB 2.0 ports; 1 1394 connector for 1 1394 port; 1 Serial port connector for a second com port; 1 VIP connector; 1 Front-panel audio connector (Mic-in and Line-out); 1 CD audio-in connector; 1 FIR connector; 1 CIR connector (Switchable for KB/MS); 1 LPT port connector; 1 Wake-on-LAN connector; 2 Fan connectors: CPU/Sys FAN; 1 I2C connector; 1 LVDS/TTL module connector (Optional); 1 +12V power connector
VIA EPIA ML6000 and ML8000
VIA CLE266 North Bridge
VIA VT8235M South Bridge
System Memory - 1 DDR266 DIMM socket, Up to 1GB memory size
VGA - Integrated VIA UniChrome AGP Graphics with MPEG-2 Accelerator
Onboard IDE - 2 X UltraDMA 133/100/66 Connectors
Onboard Audio - VIA VT1616 6 channel AC' 97 codec
Back Panel I/O - 1 PS2 mouse port; 1 PS2 keyboard port; 1 Parallel port; 1 RJ-45 LAN port; 1 Serial port; 2 USB 2.0 ports; 1 VGA port; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
VIA EPIA MII12000 and MII10000 and MII6000
VGA - Integrated VIA Unichrome AGP graphics w/MPEG-2 Accelerator
Onboard Floppy - 1 x FDD Connector
Onboard Audio - VIA VT6103 10/100 Base-T Ethernet PHY
Onboard 1394 - VIA VT6307S IEEE 1394 (Optional)
Onboard CardBus / CompactFlash - CardBus Type I & Type II; Ricoh R5C476 II / R5C485 CardBus Corntroller
Back Panel I/O - 1 CardBus Type I and Type II slot +1 CompactFlash Slot; 1 CompactFlash slot; 1RJ-45 LAN port; 1 PS2 mouse port; 1 PS2 keyboard port; 1 Serial port; 2 USB 2.0 ports; 1 VGA port; 1 RCA port (SPDIF or TV-Out); 1 S-Video port; 1 1394 port; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports; 1 Front-panel audio connectors (mic-in and line-out); 1 CD Audio-in connector; 1 FIR connector; 1 CIR connector (Switchable for KB/MS); 1 Wake-on-LAN connector; 1 LPT port header; CPU/Sys FAN/Fan 3; 1 Connector for LVDS module (Optional); 1 Serial port connector for second COM port
VIA EPIA M10000 and ME6000
VGA - Integrated VIA Unichrome AGP graphics with MPEG-2 Accelerator
Onboard Audio - VIA VT1616 6 channel AC'97 Codec
Back Panel I/O - 1 PS2 mouse port; 1 PS2 keyboard port; 1 Parallel port; 1 RJ-45 LAN port; 1 Serial port; 2 USB 2.0 ports; 1 VGA port; 1 RCA port (SPDIF or TV out); 1 S-Video port; 3 Audio jacks: line-out, line-in and mic-in; can be switched to 6 channel output
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports; 2 1394 connectors for 2 1394 ports; 1 Front-panel audio connector (Mic and Line Out); 1 CD Audio-in connector; 1 FIR connector; 1 CIR connector (Switchable for KB/MS); 1 Wake-on-LAN connector; CPU/Sys FAN/Fan 3; 1 SMBUS connector; 1 Connector for LVDS module1 Serial port connector for a second com port
VIA EPIA 800 and 5000
VIA C3/EDEN EBGA Processor
VIA PLE133 North Bridge
VIA VT8231 South Bridge
System Memory - 2 PC133 DIMM sock, Up to 1 GB memory size
VGA - Integrated AGP 4X Graphics
Onboard LAN - VIA VT6103 PHY 10/100 Ethernet
Onboard Audio - VIA VT1612A 2 channel AC'97 Codec
Back Panel I/O - 1 PS2 mouse port, 1 PS2 keyboard port, 1 VGA Port, 1 Parallel, 1 RJ-45 LAN port, 1 RCA port (SPDIF or TV out), 1 S-Video port, 2 USB 1.1 ports, 1 Serial port, 3 Audio jacks: line-out, line-in and mic-in
Onboard I/O Connectors - 1 USB connector for 2 USB 1.1 ports, 1 CD Audio-in connector, 1 FIR connector, 1 CIR connector, 1 PS2 connector, 1 CPU/Sys FAN
Jetway 627F Series
Support VIA C3 processor in EBGA packaging, for 133MHz Front Side Bus Frequency
VIA VT8623 North Bridge
VIA VT8235 High Bandwidth Vlink Client South Bridge
1 x 184-pin DDR Module Sockets Support Max 1GB, 2.5V DDR266 DDR SDRAM
Support 2 x Ultra DMA 133 IDE Interface
128bit 2D/3D graphics engine
Support NTSC/PAL TV system S-Video/AV Output
6xUSB 2.0 Ports, 1xParallel Port
Jetway / Phylon / Versa / Vista J7F2WE
VIA CN700 Northbridge + VT8237RP Southbridge Chipsets
Chipset (MCP51G)
Support VIA C7 Nano-BGA processor
CPU core speed
1G0 is 1.0GHz C7 CPU [All]
1G2 is 1.2GHz C7 CPU [Jetway Only]
1G3 is 1.3GHz C7 CPU [Phylon Only]
1G5 is 1.5GHz C7 CPU [All]
Support Front Side Bus 133MHz
Single Channel DDR2 400 Memory DIMM
Support 2 Serial ATA Devices with RAID 0, 1
Support 2xAD Connector With Expansion Daughter-boards
Ethernet LAN Supported
AC’97 6 Channel Audio CODEC
VIA VT6307S IEEE1394a Controller for J7F2E / J7F2WE
Jetway J7F4 Series
VIA VT1622A TV encoder
Ответить с цитированием
