Показано с 1 по 5 из 5
Тема: Centrafuse 2.0 RC2
    AlexSt_66
    Гость
    По умолчанию Centrafuse 2.0 RC2
    Вышел subj...
    Из нового вот что:
    NEW NAVIGATION UPDATES
    * Faster map refresh rate, much smoother
    * TMC (in Beta, requires D6 supported TMC receiver such as GNS 9833)
    * Touchscreen friendly map menu when touching the map
    * Added "add to favorite" to touchscreen friendly map menu when touching map, auto loads to add favorite to specific folder
    * Added ability to show favorite folders on the map by using hide/show button in favorites section of navigation, this auto sets up alerts at 500m and then another at 100m
    OTHER NEW FEATURES SINCE 2.0 RC1
    * New option in settings "Create System Report" to package up all CF logs into 1 file, to help in debugging user issues
    * Option to save system logs to USB device when created
    * Updated Nav engine with 2x faster graphic updates
    BUG FIXES FROM 2.0 RC1
    * Weather Plugin not working
    * Volume/Balance issues
    * License Reactivation issues
    * Radio does not work on resume
    * Improper message displayed when BsSDK.dll not found
    * Main Title Paint problem
    * Mixer sliders going off-screen
    * Silabs/Adsinstantfm not functioning whatsoever
    * Infill Plugin not working in new 2.0RC1
    * Radio settings shows 'Graphics' as the title.
    * HD Radio will not initialize
    * Missing Translations
    * DVD does not work in 2.0
    * HD/Pictures switching causes issue in media
    * Loading Pictures Single-Click Issue
    * Xheo Licensing issues
    * Skin always says Aura in settings
    * Cant select COM port for HD radio
    * Normalization option doesnt save
    * Dim settings are not being reset when exiting CF
    * Can't make calls from Contacts List
    * Cannot set Music Sound Device
    * ATT mute not working correctly
    * Title scroll options in wrong setup section
    * Music will not pause or show in playlist after Artist browse
    * CF Shortcut not correct after install
    * Bug selecting song in Music then exiting
    * Voice Rec does not work when music is pauses
    * WiFi setup is missing label for 'Refresh Networks Interval'
    * Closing CF when running as shell is not loading Explorer
    * Gestures messing up being able to move map around in nav
    * Vista icon / start button on Vista doesnt hide with taskbar
    * voice command next track doesnt switch the track
    * Volume reading not precise on volume popup
    * After return from hibernate, radio playback line will not unmute
    * Shutdown and Restart options do not work on cf exit
    * Phone does not re-connect after standby
    * Position text shows -00-01 when CF starts w/o music
    * Gestures on visulisations don't work, disable gestures on visuals
    * DVD Menu display issue
    * XM audio does not unmute after Nav Voice Prompt
    * Favorites not being saved
    * Graphics resolution text displayed off on screen
    * location settings in Weather do not save
    * Phone volume way off
    * Music resumes after phone call when it shouldn't
    * Issue loading and playing videos
    * Sirius Channel List will not completely refresh
    Что интересно - с ним в комплекте также идёт IVT BlueSoleil 6.0.221.0, о котором нет даже намёка на их ( IVT/BlueSoleil ) официальном сайте, последняя версия там по-прежнему 5-ая. И куда-то подевался TV plug-in...
    Взять 2.0 RC2 можно с официальной страницы загрузки: http://www.fluxmedia.net/downloads.aspx
    Последний раз редактировалось AlexSt_66; 11.05.2008 в 19:25.
    По умолчанию Re: Centrafuse 2.0 RC2
    Быстрые они
    Цитата Сообщение от Chip
    Быстрые они
    обещают каждую неделю-две выпускать обновления, пока релиз не выйдет.
    угу , так и есть... читал тут про РЦ1.... пошел на сайт скачать, а там РЦ2... вот уже часа 4 мучаю РЦ2
    Выручайте!
    Поставил build 508.
    Он стартует, но нажатие люой кнопки приводит к зависанию.
    Сперва попробовал апгрейд. Увидел проблему.
    Потом деинсталлировал. Та же фигня.
    Причем, на самом деле он не виснет, а ничего не делает.
    Например, нажимаю "выключение" (справа внизу), она подсвечивается синим.
    Жму "Music" - тоже синеет!
    И еще странность. Она подставила мои переназначенные кнпоки, хотя я после деинсталляции удалил (переименовал) остаток директории (она оставила непонятные файлы Russian.xml)
    Т.е. ставилась она с нуля, и я рассыитывал, что начнется визард, спрашивающий меня о всяких директориях для музыки.
    ОК. Удалил директорию Centrafuse из Моих Документов. Стартовал визард.
    Начал ковырять натсройки. Но как внутрь провалюсь, так ни OK, ни Close не работают! Синеют (в т.ч. обе на одном экране) и все!
    Последний раз редактировалось Caravancheg; 18.05.2008 в 00:04.
