Показано с 1 по 10 из 42
    По умолчанию Появился Centrafuse RC4
    Centrafuse RC4
    Из нового - новая версия бт стека, правдв ограничение на 5 мб осталось
    FREE UPDATE
    This release is being provided as a FREE update to Centrafuse 1.20+ and 2.0 RC1, RC2, and RC3. We recommend (but not required) that you uninstall all previous version of Centrafuse and all previous plugin installs before installing 2.0 RC4. See "FRESH INSTALL" instructions below.
    UPGRADING YOUR EXISTING LICENSE KEY
    To upgrade your 1.20 license to a 2.0 license, visit your My Account page. If you do not see your license key on your My Account, please contact Support.
    From the My Account page, click the UPGRADE KEY link below to produce your new 2.0 license key. To install the Release Candidate for 2.0, download and install directly over your current 1.20 version. If you have the XLE version installed, the 2.0 installer will recognize this and leave your maps and settings intact.
    RELEASE CANDIDATE
    Centrafuse 2.0 RC4 is a 4th release candidate, and contains many bug fixes to RC3, but it is still not considered a stable release. It should be expected that there will be issues surfacing on various systems. With the help of users, we will be working to resolve these issues quickly and hope to be able to provide updates weekly or bi-weekly.
    ** NEW ** IN RC4+ YOU CAN SELECT YOUR RECORDING AND PLAYBACK DEVICE FOR HANDSFREE AUDIO
    Now in phone settings you can select which recording device (microphone), and which playback device, that Bluetooth will use for handsfree audio. This should fix all issues where user experiences their mic not working or hearing no volume from the phone through system speakers.
    ** NEW ** IMPORTANT!! RC4 COMES WITH A NEW VERSION OF BLUETOOTH STACK (6.0.227)
    You must install the new bluetooth stack if using phone in Centrafuse. This will erase your bluetooth devices and settings. This is IMPORTANT: You MUST delete the pairing off your phone before trying to re-pair your phone to Centrafuse with the new stack installed.
    CENTRAFUSE SYSTEM REPORT AND FORUM USER BUG REPORTING
    You can now create a system report in which all Centrafuse log files, and other cf config info, are packaged into one easy-to-post .flux file. These logs will help us track down bugs reported. So, if possible for you, when reporting issues from now on, please include the system report in your post when reporting on that issue. To create a system report:
    http://forums.fluxmedia.net/showthre...8733#post18733
    INSTALLING OVER CF 2.0 RC3
    Note that we recommend a "fresh" install for all RC installations (see "Performing a Fresh Install" below). However, the RC4 installer will auto uninstall any old versions of Centrafuse currently installed, meaning you can simply install on top of your existing RC3 installation.
    PERFORMING A "FRESH" INSTALL
    1. For XLE and NAV customers, copy (or move) all Map Directories from CF runtime folder to another location on your hard drive
    2. Uninstall any previous versions of Centrafuse
    3. Unplug any bluetooth dongle
    4. Uninstall any previous versions of Bluesoleil and any other bluetooth stacks or software on the system
    5. Remove CF settings directory from your LocalAppData folder - “Users\[UserName]\AppData\Local\Centrafuse” directory (vista), or “Documents And Settings\[UserName]\Local Settings\Application Data\Centrafuse” (xp)
    6. Remove Centrafuse runtime directory - "Program Files\Flux Media"
    6. Reboot Windows
    5. Install Centrafuse 2.0 RC4
    6. Uncheck "Run Centrafuse Now" checkbox when install completes
    7. For XLE and NAV customers, copy (or move) the map directories back to the CF runtime folder
    8. Re-insert any bluetooth dongle, make sure gray Bluesoleil icon in Windows system try lights blue
    9. Start Centrafuse
    USB BLUETOOTH DONGLE ISSUES
    If you are experiencing difficulty with our Bluesoleil stack and it recognizing your BT device, please see the below link to add support for your dongle. You must follow all instructions carefully, if you do do your dongle will most likely end up working (no guarantees though :-))
    http://forums.fluxmedia.net/showthread.php?t=2715
    *** IMPORTANT NOTES ***
    This version is a 4th release candidate, and contains many bug fixes, but it is still not considered a completely stable release. It should be expected that there will be issues surfacing on various systems. With the help of users, we will be working to resolve these issues quickly and hope to be able to provide updates weekly or bi-weekly.
    It is recommended/required that you remove all other bluetooth stacks/software/drivers from Windows before installing Centrafuse (if you will be using Centrafuse Phone feature). As with most driver installs for a USB device, your USB bluetooth dongle should NOT be inserted before CF Bluetooth is installed. So, remove your bt hardware, uninstall any existing bt drivers/stacks, install CF, then re-insert your bt hardware.
    The Bluetooth stack provided with the 2.0 RC's is a trial version and currently has a 5 MB transfer limit. If after one or maybe a few phone calls the Bluetooth stops working, you will need to restart your PC to re-initialize the Bluetooth driver. This is only a limitation of the BlueSoleil trial edition within this Release Candidate and will not have this limitation when officially released ** UPDATE ** Bluetooth serial codes are close to being dispursed for current customers.
    All 3rd-party plugins used with CF 1.47 and earlier should reference the new cfplugin.dll and be recompiled under .NET 2.0
    Settings in 2.0 are now defaulted to show the Basic Settings mode. Advanced Settings can be enabled in 2 ways.
    To enable Advanced Settings temporarily, hold down the "+" button in the Main Settings Screen for 6 seconds.
    To permanently enable Advanced Settings, similar to older version of CF, pass the -advsettings command line option when starting Centrafuse.
    Each settings group that used to hold a Line-In value and had Buffer functionality will now hold a Record-Line-In value and a Playback-Line-In value, which will work with Buffer On, and Buffer Off, respectively.
    Basic Event Logging has been added in RC2 to better help us diagnose user issues. Event Logging can be enabled in General Settings (an advanced setting), or can be enabled by passing the -logevents command line option when starting Centrafuse. Function specific logs are also created for things like OBDII, Phone, and SatelliteRadio, these can all be enabled within their respective settings screens. New in 2.0 RC2, you can "Create System Report" from Settings that will package up all these log files for you.
    Some tips to follow on pairing your phone if things are not seeming to work for you:
    1. Delete the pairings from both your phone and Centrafuse (in CF just go into phone settings / device list and click the '-' button.
    2. Give your phone a power cycle, and give Centrafuse an exit and a restart.
    3. Re-pair your phone and CF, try initiating the pair from your phone, not from Centrafuse. Or on another try, initiate the pair from Centrafuse, but type in incorrect pincodes the 1st time to make pairing fail. Then click 'PAIR' button again, and go ahead and type in matching pincodes to create pair.
    4. Save out of settings. See if this makes any difference.
    *** 2.0 RC4 RELEASE NOTES ***
    NEW FEATURES SINCE 2.0 R3
    Updated user manual
    Send a voice attachment in your emails
    Select microphone and playback device for handsfree audio
    Buffer correction - no more position label jittering and out-of-sync buffer over time
    Volume soft off / soft on during standby/resume
    Multiple pages for mixer levels to show any number of lines
    Ability to delay resume, to allow USB devices to init
    TMC for Navigation (Europe only at this time). See FAQ for compatible hardware.
    Ability to support multiple CAM devices, no setup required clicking CAM will load the initial CAM device, click the label to toggle additional CAM devices, you can set the default from Settings\CAM
    New address in GPS skips directly to entering the address, a new MODE button has been added to pull up the different search methods, it defaults to your last used
    Ability to select Speech voice profile from Settings
    BUG FIXES FROM 2.0 RC3
    CF hanging on warning dialog
    Play timer going crazy when listening to music
    After install of RC2 Sirius icon replaced by XM
    Disconnecting phone leaves headset icon on
    Dial button always says "Cannot dial"
    Click Sound Level not adjustable in Setup
    ATT mute dose not work in video viewing screen.
    AAC and Missing tracks don't auto go to next song
    Cannot configure or use voice
    It still says Trial after registered in System Information dialog
    When radio loads at startup, agree box shows behind window and locks up
    The text random show in status bar while in satradio/radio
    COM port listings not in order, wrong descriptions
    Infill Settings Issues
    Shutdown starts Windows when running CF as shell
    Album art view skips two pages
    After phone call music resumes on left channel only
    Multiple crash scenarios when closing application
    Pressing a button after you darken the screen, click not ignored
    ATT standby issue
    Position number showing negative after the semi colon
    Playing track stops with 1 second left, doesnt advance
    HQCT - mute does nothin when in non-buffer mode
    Exiting radio/media, long delay before next click registers
    VCard Importer doesnt work
    Volume wouldnt go down in first run, Balance issue Phone and Nav
    Sirius Buffer issue with Silabs USB Radio installed
    Mute button does nothing when listening to radio
    Adjusting volume should disable ATT
    Play/pause button out of sync after loading album
    Phone has no volume during active call
    Web text size dose not chage when selecting largest
    Wav output gets muted when leaving radio
    Volume overlay not showing up
    turn icons in navigation not correct with left hand driving
    Language still changes after cancel settings
    Buffer not rolling over correctly
    ODBII sometimes doest reconnect
    Cam fails to record
    Position label jitters in buffer mode
    Mixer sub-control still doesn't work
    Playlist not reloading when CF starts
    CF locked while phone is connecting
    Delay while loading videos screen
    Enhanced graphics cause music menu to not open
    Radio screen not showing on first click
    Invalid RPM reading in OBDII, showing degrees F
    Gestures not saving when set in settings
    DVD mute button painted opposite of true state
    CF sometimes crashes on hibernate with phone connected
    Call hangup mutes wav volume
    Cannot set TTS voice unless speech is enabled
    Setup transparent buttons not in Onyx Skins
    Play button skin bug for Aura
    ATT Mute settings should be in Audio/Video settings
    Nav not working after hibernation
    Video playback stops after 1 minute
    Mp3Car forums will not accept .flux extension
    Log volume goes from min to max with one click
    Can't control volume after going into radio or phone settings
    Mic not working with phone
    black vis picture box appears om top of skin when video reloads
    pause button is play icon in down state, video/dvd only
    Volume popup text not displayed
    Balance gets set all the way to 1 side
    Changing skins causes inet icon to turn red
    По умолчанию Re: Появился Centrafuse RC4
    Здорово, но скачать не могу. С моим каналом льется часа 3-4, потом связь рется и все.... А Donwload master через их дурацкий https не качает.
    Может кто подскажет как или с них лить с докачкой, и куда-нито выложит, чтобы я с докачкой забрал... Ну очень хочется...
    Говорят, там даже клава русская встроенная появилась...
    Пользователь Аватар для DimNsk
    Цитата Сообщение от archer
    FREE UPDATE
    Перевод:
    Этот релиз настоящее время оказывается как бесплатное обновление для Centrafuse + 1,20 и 2,0 RC1, RC2 и RC3. Мы рекомендуем (но не обязательно), что вы удалите все предыдущие версии Centrafuse и все предыдущие установки плагина перед установкой 2,0 RC4. См. "FRESH УСТАНОВИТЬ" ниже инструкциям.
    кто пробовал поверх 1.20 СТАВИТЬ лицензия слетает?
    Последний раз редактировалось DimNsk; 12.06.2008 в 14:01.
    Там так же написано, что требуется реактивировать лицензию на сайте.
    Формат поменяли.
    Т.е. если честно купленная - то бесплатный апгрейд. А "левая" уже не подойдет.
    Скачивай браузером Opera в нем встроена функция докачки.
    странно что еще не поломали защиту, но по всей видимости ждут релиза
    Кстати, а чего там с BlueTooth стало?
    В RN написано, что сменили тоже.
    Не научилась, часом, с бесплатным widcomm работать?
    Скачал 170 мегов. Потом пришлось нажать "возобновить".
    Файл заменился на 141 байт "файл был перемещен..."
    А зарегистрированные пользователи могут по-человечески скачивать? Или тоже только через https?
    Последний раз редактировалось Caravancheg; 13.06.2008 в 00:17.
    AlexSt_66
    Гость
    Ну не знаю... У меня с первого раза всё абсолютно нормально скачалось, никаких проблем, без всяких download manager'ов...
    Ну, если б я в Москве жил, и у меня бы скачалось.
    А когда 128 К и каждые 2-3 часа PPTP переустанавливается...
    Впрочем, вопрос снимается. Я его по-другому решил.
