Показано с 1 по 1 из 1
    По умолчанию Продам VIA EPIA MII12000G Mini-ITX Mainboard with Fan
    http://molotok.ru/my_allegro.php?pag...ions&type=sell
    Chipset VIA CLE266 northbridge VIA VT8235 southbridge
    System Memory 1 DDR266 DIMM socket (DDR400 is backward compatible)
    Up to 1GB memory size
    VGA Integrated VIA UniChrome AGP graphics with MPEG-2 accelerator
    Expansion Slots 1 PCI
    Onboard IDE 2 ATA 133 (40-pin)
    Onboard CompactFlash CompactFlash type I and type II
    Ricoh R5C476 II/R5C485 CardBus Controller
    Onboard USB 4 USB 2.0
    Onboard LAN VIA VT6103 10/100
    Onboard Audio VIA VT1616 6 channel AC'97 codec
    Onboard TV-Out VIA VT1622A TV-out
    Onboard 1394 VIA VT6307S IEEE 1394 (FireWire)
    Supported Resolution 1400 x 1050 maximum (VGA) 1024 x 768 maximum (LVDS/TTL)
    Back Panel I/O 1 CardBus type I and type II slot
    1 CompactFlash slot (non-bootable)
    1 LAN port
    1 PS2 mouse port
    1 PS2 keyboard port
    1 RS-232 COM port
    2 USB 2.0 ports
    1 VGA port
    1 TV-out
    1 S-Video port
    1 IEEE 1394 port
    3 Audio jacks: line-out, line-in, and mic-in (Smart 5.1 Support)
    Onboard I/O Connectors 2 IDE 40-pin connectors
    1 USB 2.0 connector for 2 USB ports
    1 Front panel audio connectors
    1 CD audio-in connector
    1 FIR connector
    1 CIR connector (switchable for KB/MS)
    1 Wake-on-LAN connector
    1 LPT port header
    1 Fan connector
    1 Connector for LVDS module (optional)
    1 RS-232 COM connector
    ATX power connector
    BIOS Award BIOS 2/4Mb flash memory
    System Monitoring & Management CPU voltage monitoring, Wake on LAN, Keyboard power on, Timer power on, System power management, AC power failure recovery
    Operating Temperature 0°C ~ 50°C
    Operating Humidity 0% ~ 93% (relative humidity; non-condensing)
    Form Factor Mini-ITX (17 cm x 17 cm)
    От 4 000,00 руб
ID:	3731   Нажмите на изображение для увеличения.
    Последний раз редактировалось virik; 25.03.2009 в 00:24.
