Показано с 1 по 10 из 13
    По умолчанию Re: во чо нашел!
    Technologies
    - Embedded hardware, X86 structure, using of original modular design technology
    - Patented hanging double system, 3D anti-shock technology
    - ITPS intelligent power management
    - patented J-COOL automotive cooling technology
    - Bluetooth technology
    - Front USB 2.0 interface standard technology
    - Support 3D navigation engine technology
    - Support CAN Bus interface technology
    3. Hardware configuration
    . the use of IA framework INTEL ULV Mobile processor, high-performance, low power
    consumption
    . whole new generation 6.5" vehicle dedicated digital touch-screen, high-definition of 384,000
    physical pixels and high brightness of 400 cd/M2, -30 -70 wide temperature range operation
    . built-in SiRFIII GPS chip, which can receive 20 channels of satellite signals, accuracy higher
    than 10 meters
    . Bluetooth module, Bluetooth hands-free, caller number display and keyboard dial up function,
    can match other Bluetooth devices for data exchange
    . Built-in DVD COMBO, support a variety of standard discs, such as CD, VCD, DVD, CD-RW.
    . AM / FM radio module, the introduction of efficient anti-jamming technology, which can
    support storing 30 channel programs
    . Amplifier module, 4 * 40 W high-fidelity audio output
    . Front Mini USB 2.0 interface, easy access mobile phones, digital cameras, DV, flash disk,
    MP3, iPod and other digital devices, and the front microphone and SD card slot
    . Steel chassis, stable and reliable
    . Digital TV modules, to support a wide range of digital TV reception standards (optional)
    . Multimedia visual reversing module, lightly pull the gear, you can automatically switch the
    full-color environment image behind the car (optional)
    . Fault detection module, OBDII function, read / remove all system fault code stored in the
    vehicle ECU (optional)
    4. Operating system and application software
    Full support WINDOWS XP, WINDOWS 2000, WINDOWS CE, LINUX operating system, and all of these operating system software. (Please refer to the softwares minimum hardware configuration needs)
    Recommend to use the exclusive intelligent car information management system and, Web GIS commanding dispatching system which are independently developed by our company based on WINDOWS XP, and has a large travel, entertainment and command dispatching function procedures, friendly interface, easy to operate
    Довно уже видел. Говарят говеная фигня, не выдерживает критики
    красивая блин
    Пользователь Аватар для andreydk
    у меня дома лежит в коробке новый монитор (второй на картинке) на столе подключал - показывает нормально - в машину пока не устанавливал, звук усилителя и радио не проверял.
    дак это полноценный комп или чисто корпус с монитором?
    Продвинутый Аватар для KonTur
    На первой фотке - мультимедия для конкретного авто.
    На второй - авто комп N52 компании Hiinfo. www.hiinfo.ru - там более развернутый каталог.
    В магазине на Школьной 72/2 (в здании МРЭО) - это в Питере - его можно потргать руками. Мне лично не понравился. Хотя наверное просто экхемпляр был замученный (чтобы хоть как-то по меню полазить пришлось добираться до калибровки экрана - была сбита). Своих денег не стоит, дороговат.
    нет - на второй - тоже монитор - я его как раз покупал у www.hiinfo.ru - это монитор с усилителем и радио - компа там нет.
    andreydk
    А скажи пожалуйста, какую функцию в твоем мониторе с усилителем и радио играет миниЮСБ разьем, расположенный в правом нижнем углу?
    И зачем на фронтенде есть кнопки навигации, веба, хендсфри и пр.пр.пр.?
    Последний раз редактировалось KonTur; 13.02.2009 в 10:56.
    andreydk
    пока не втыкал в это разъём ничего - предполагаю, что это просто как юсб хаб работает - сзади есть ещё один ЮСБ шнурок, который идёт к компу для тач скрина - предполагаю, что через этот шнурок и коннектится передний ЮСБ разъём с компом - попробую отпишусь. фронт енд на кртинке - просто для красоты - само меню монитора - тупо синий экран с буквами. прикрепил изображение моника моего на столе с подключенным ноутом (фоткал на телефон)
